? difference between bx22 and bx23
   / ? difference between bx22 and bx23 #1
gchova
Eastern Pennsylvania
Kubota L39, B3030, Ford 1500, others
Anybody know what are the differences between a BX22 and BX23? I'm thinking of getting a used BX22, but don't want to miss any important new features of the BX23. I know in other posts the 4 position valve was mentioned, ? anything else?
Thanks very much,
George
   / ? difference between bx22 and bx23 #2
a form of "cruise control" and a nicer seat.
   / ? difference between bx22 and bx23 #3
I believe the BX23, or at least the later models of it, has a physically smaller (though same hp) engine, which will not take a block heater, but will take an inline hose heater.
Also think the 23 had more kill safety switches than 22. If you rise up at all to see while running MMM, it stops.
This is a good ? for Junkman but he hasn't posted much the last week or so-must be busy puttin' the grass catcher together, gettin' seat time, or up to some new scheme or invention.
Thanks very much for the information. So far, the differences listed wouldn't make a great deal of difference to me!
George
   / ? difference between bx22 and bx23 #5
The engines are different. Both are 22 HP but the 23 has a new designed engine. But as others have said the differences are not major except the 4 way valve.
   / ? difference between bx22 and bx23 #6
The BX22 and 23 have the same engine. It's the BX2200 and the 2230 that have different engines.
Neither the BX22 or 23 have cruise control.
On the BX23, the 4 way FEL valve is standard, and optional on the BX22.
The BX23 also has more safety switches (rigged to the seat) while the BX22 only has an ignition interlock if the tractor is in gear, or if a pto is engaged.
The BX23 has a higher backed seat.
The stickers are different too.
   / ? difference between bx22 and bx23 #7
I believe the BX23 now has an FEL joystick control that stays with the tractor for use with other front mounted implements. My neighbor's BX22 has the joystick control that comes off the machine and stays with the loader. Don't know if that would be an issue for you or not.
   / ? difference between bx22 and bx23 #8
As far as I know the BX-22 had a D905. My Early production run 2004 BX-23 also has D905 motor.
Is it really true that you can't put a block heater on a 902????
I have never heard that.
Junkman can verify or correct me on this one.
   / ? difference between bx22 and bx23 #9
When I checked the Kubota site, the BX2230 is currently listed as having the D902 engine and the BX23 as having the D905. As I went back and checked the old threads about block and inline heaters for BX's, it does seem that all the discussion about not being able to use the block heater was in relation to the BX2230, rather than the BX23 as I mistakenly posted above. Below are three old threads I found regarding the BX2230 with D902 engine being able only to take the inline hose heater and not a block heater:
This is the most recent.
This one's older.
This one's oldest of these three.
I forgot about the FEL joystick being changed. On 'Bota's site I saw the new seat; looks comfy!
   / ? difference between bx22 and bx23 #10
The engine in the BX23 is the D905-E-BX
Specs
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 POLARIS XP1000 RANGER (A51222)
2019 POLARIS...
Landoll Hauloll (A51039)
Landoll Hauloll...
