Difference Between a JD 80 and JD 440?
   / Difference Between a JD 80 and JD 440? #1
wsp617
Wisconsin
JD 1070
I just picked my JD1070 with a JD 80 FEL. I also see the 1070 with the 440 FEL. Is there much of a differnce between these two models? I ask because I may need to replace the loader. The pivot points are getting quite worn.
   / Difference Between a JD 80 and JD 440? #2
Can you not replace the pins and bushings? Those loaders are the older style i believe, if you are really gonna get a new loader I believe the 300cx would be just the right size. Im not sure, so dont throw rocks if im wrong, but I think you would need new brackets for the loader as it is quick attach.
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2014 FORD F-350 (A53422)
2014 FORD F-350...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2012 International Vactor Sewer Truck (A52377)
2012 International...
