difference between a 4310 and 990?
/ difference between a 4310 and 990? #1
willy1947
Solsberry, IN
Kubota L3830 GST
Could someone briefly sumarize the differences between the two? I priced a 4310 w/FEL and powerReverser for around $18K. They never mentioned a 990 as an option only a 790 as another option.
Thanks,
Dave
/ difference between a 4310 and 990? #2
Have you compared them on the Deere website? I don't know the 990 all that well - but I know the 790 is a good solid little tractor - and the 990 is the larger more powerful model. I wanted the "frills" i.e., all the electronic goodies that came on the 4310, motion match, load match, electronic switching on 4wd, cruise control, tilt wheel. Yeah it sounds soft, but the 4310 is a tough tractor... just pretty loaded. I think the 990 is just a good solid basic tractor with a decent amount of muscle. If you're looking to save $$ then I think it warrants a look.
/ difference between a 4310 and 990? #3
Mercedes Benz versus stripped down Checker Taxi Cab.
The same could be said about the New Holland TC29 versus the old workhorse TC30. The same could be said about the Kubota B2910 verses the plain vanilla B7800.
One is the deluxe version with all the whistles and bells, the other is a basic workhorse.
/ difference between a 4310 and 990? #4
I love my 4310, but your sig says Willys 1947, so you are probably inclined towards No Nonsense, No Frills. You might just LOVE a 990!
I almost jumped on a 2A a while back, I wish I had... Great machine! OlllllO
I have a pic of one with the stock Green and Yellow... Do you have a pic of yours?
Yep, got lots of pictures of my 2A:) I've also got a 1946, but it is just for parts or a future project.
The pictures are at home on my computer. I'll try to get some posted or sent to me. Drop me an email at home, willy47@bluemarble.net, and I can send you a picture.
A 990 might just work, but I also want to "one up" my friends:) However, "one upping" caused me to buy a 2004 dodge dually, 4x4, diesel. It's starting to get expensive to do /forums/images/graemlins/smile.gif The local rental store has one. I may rent it and see what it is like. This should help me make up my mind.
Thanks,
Dave
/ difference between a 4310 and 990? #6
Well, I work with a Mopar Dealer, so I am not the best one to offer sympathy...
/ difference between a 4310 and 990? #7
Hi Dave,
I sort of went through this last year and ultimately bought the 990. It was delivered last September and I've about 35 hours on it so far.
The John Deere web site has been updated since I last went there and it's easier to find specs on the two. A few major points are HP -- gross and PTO. 3PH lift capacity. Engine and final drive type.
If you check out the Build Your Own section on the web site you'll see there are quite a few more options available for the 4x10 series. My impression was the 4310 generally compared more closely to the 790 and the 4510 to the 990.
In any case, the 990 and 790 are gear only, so if that's a show stopper, your decision is automatically directed away from the 790/990.
I've been satisfied with the basics for my first tractor. I've a 1/4 mile gravel driveway (box scraper work), a big hole to fill in (loader work), and I've taken sweet revenge on the multiflora rose (mower work) so far.
Dave
/ difference between a 4310 and 990? #8
Dave
I'm pretty sure the 790/990 has dry clutches and brakes and the 4310's are wet. The PTO is independant on the 4310 but not on the 790/990s which makes mowing tougher. The 4310 is way more comfortable for me the biggest reason being my feet kept getting tangled up on the 790/990 arrangment. Also, the foot throttle was useless (real touchy) on the 790 but is real smooth on the 4310. I wanted a stick so that wasn't an issue but with more gears the 4310 can go slower when needed.
Joel
/ difference between a 4310 and 990? #9
Hi
I have a JD990 with the 430 loader. It has worked great for me. I wish JD would have put the 460 loader on the 990; It's a bit beefier.
The clutch and gears are very smooth and I have not had any problems. I like the extra HP and weight for pushing piles of limbs, gravel, dirt, and anything else in the way.
I would suggest you test drive both models and see what works for you. The 4000 series with the hydro trans is generally considered to be the "cadillac" series. If you need (want) the extra HP and weight, you may consider moving to the 4610 or 4710, which is more comparable to the 990. Plus they have the 460 loader.
I used to have a 56 Willys, but have "upgraded" to the CJ series some time ago. They are lots of fun.
Good Luck
John
/ difference between a 4310 and 990? #11
Dave,
In addition to the other comments, I went 4 wheel drive and I'm glad I did. I've moved quite a bit of dirt (by my standards, say over a hundred loads the last two weekends) and the 4WD helped get fuller bucket loads and pulled me through a few times I might have had to jockey around otherwise.
Also, the PTO on the 990 is independant. You just need to get used to the two stage clutch -- which I've found to be no big deal over the approx 4 hours of mowing I've done so far. I push the clutch and I stop but the mower keeps going. Push the clutch ALL the way down and now the PTO stops.
I, too, find the foot throttle pretty useless. I always use the hand throttle. As a person 5'-10 and 150#(ish) I didn't find the 790's operator station too objectionable. And the 990 is no problem for me.
Dave
/ difference between a 4310 and 990? #12
Oh Yeah ! 4WD is an absolute. I forgot to mention it because I never look at anything without it.
Thanks Monroe40
John
/ difference between a 4310 and 990? #13
I too love my 990 and the motor leak seemed to stop itself now. But anyway I had the 4300 and now a 990 and the 990 is a great basic tractor. The dual stage clutch I find not to be a problem compared to the independent on the 4310. The 990 is planetary final drive where as the 4310 is spur gear. Planetary is a little more durable. Both are pretty good machines just if you want a hydro or not. I am partial to the 990 but the 4300 was a comfortable machine with the optional armrests on the seat. Also the 990 is a 4 cyl. compared to the 3 cyl of the 4310. Way more torque at a lower RPM.
/ difference between a 4310 and 990? #14
I thought the 990 came with a black seat and the 4310 came with a yellow seat. Can anyone get that verified? That in itself should make it clear which way to go. /forums/images/graemlins/grin.gif
/ difference between a 4310 and 990? #16
Sorry for the mis-info on the 990 PTO setup. I was told the 790 and 990 were essentially the same but for horsepower and frame. I wanted preferably an independant clutch but a split clutch was OK too. I was pointedly told the 990 had neither which pretty much ruled it out, and I had only tried out the 790. As someone else experienced, it seemed the dealer was maneuvering the 990 out of the mix. Don't know why. For me possibly it might have been because I didn't care about the extra horsepower.
Joel
/ difference between a 4310 and 990? #17
I am very pleased with my 990 also, especially in the cost. A 4710 would be preferable but would have cost me a _LOT_ more money. I wouldn't trade for a 4310 myself. I use the foot throttle all the time, I have no problem with it. It's a little sensitive but no big deal once you get used to it. The only time I use the hand throttle is if I want to keep the PTO at 540 like for cutting.
As for why it was never mentioned, the dealers don't seem to push the 990 at all. You can find 790s on most dealer's lots but I never saw a 990 until I ordered mine and it came in.
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2019 John Deere R-4038 (A63688)
2019 John Deere...
