Difference between 2 pt and 3 pt
   / Difference between 2 pt and 3 pt #1
pennwalk
Veteran Member
Lancaster PA
Yanmar 186D
What is the difference between 2 point and 3 point hitches? Which implements use which? Can you easily switch back and forth. Are there special parts? Where can you get 2 pt and 3 pt hitch parts?
Chris
   / Difference between 2 pt and 3 pt #2
Most peopel are familiar with 3 point hitchs but 2 points are the exception to the tractor hitch rule. I will try to explain the best and shortest way I can. I see them on a lot of grey market tractors with tillers. Imagine your traditional 3 point set up. Now remove the lower lift arms. You will be left with the upper arms and the verticals hanging from the upper lift arms. The tiller attaches to the rear of the tractor around the same place that the lower lift arms would attach. This is the pivot point of the tiller. The verticals hanging from the upper lift arms then attach somewhere to the top of tiller. Another 2 point set up that I have seen has been on older full size American tractors. They have the lower lift arms that you would normally see on a 3 point hitch but instead of having lift pin balls at the ends of the arms, they have a socket that the implement slides and locks into. The tractor I saw with this set up also had regular ends that could go onto the hitch and a toplink bracket so that you could use regular 3 point implements. I hope this explains it.
   / Difference between 2 pt and 3 pt #3
can someone post a good pic of a 2 pt hitch? thanks, bw
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
