Tires Diff between R1 and R4 tires?
   / Diff between R1 and R4 tires? #81
I know that picture well!! Last time I was stuck like that was in my wet clay area that I should have known better, but tried anyway. Ended up high and dry, or wet should I say:D Had to drag it out with the excavator....should have been using that anyway, but I also knew it was available (part of the problem I guess). R-1's wouldn't have helped me as when you cut through you're all done. Live and learn I guess.
Cool video :thumbsup: Looks like my woods.
Wish I had more excuses to work out there. Very relaxing, good karma.
   / Diff between R1 and R4 tires? #82
Hmmm, I was figuring it was just a matched set on the tractor and a matched set on the duels. Maybe there is a reason for that, which obviously I have no clue why??:confused:
Because the set of tires used for duals were probably far cheaper than the oem's on the tractor.
   / Diff between R1 and R4 tires? #84
I realize it was put forth in the spirit of levity and I responded in kind. But to be serious if only for a moment, I like the looks of both. One of the problems, if you would call it that is that many people get really skinny Ags. I am certainly no expert on tires, but I like a wide tire. I realize for some applications a narrow tire is essential.
Yes, a very valid point here by TripleR...once again.:thumbsup:
   / Diff between R1 and R4 tires? #85
Since this is a tire thread, maybe you can answer a question for me. I notice that the tread is different between the main tires and the duels. Is this just a manufacturer thing or is there a purpose for the different spacing of the lugs/bars?(
Lug spacing and angle are chosen to give best traction characteristics in the soil type range they are made for. With fewer lugs you have more intense pressure to bite into and thus interlock with hard ground. With more lugs you have more biting edges, more contact surface. There are applications for both strategies. The choice on those duals may have just been what was available or the owner may have conciously chosen the different pattern to have a bit of the benefits of both. :confused3:
larry
   / Diff between R1 and R4 tires? #86
I need someone's approval. Anyone's approval.!!......
How do these look.??...:laughing::laughing::cool:
   / Diff between R1 and R4 tires? #87
Pictures of the pond now under several feet of water. I didn't get as many as I wanted especially of the slicks and tractor in trenches 4'-5' deep with the fram grounded.
   / Diff between R1 and R4 tires? #88
   / Diff between R1 and R4 tires? #89
Looking good to me, Bro!
Especially with that mighty fine tool box mounted back there...
   / Diff between R1 and R4 tires? #90
Personally, I like the look of Ags better than R4's........But what do I know..........I gots Turfs:laughing:
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A57192)
UNUSED INDUSTRIAS...
6 HITACHI WEDGEDOCK COUPLER (A57192)
6 HITACHI...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
