Oil & Fuel diesel wont start
   / diesel wont start #11
<font color=blue>...The temp was about 18 degrees out and its not in a heated garage.Now the tractor will not start...</font color=blue>
Well... I read some, but not all the posts... it still sounds like you're gelled up...
Without reinventing the wheel and opening up all your fuel lines and causing 5 more problems than when you first started... I'd get a salamander and heat that baby/area up to some nice tropical temps... /w3tcompact/icons/blush.gif
Then give it a try... if the temps were 18 degrees and it started and then shortly stalled minutes later... you either ran out of fuel or you are gelled up... /w3tcompact/icons/frown.gif
   / diesel wont start #12
Have to agree with John, forgot about the cold thing. Around here we never get cold enough to affect the fuel.
   / diesel wont start #13
Ok tell me if this is normal for a diesel engine or do I have a problem. I have a BX 2200, went to start it today, about 15F and was very hard to start. I turned the key and got the glow plugs going for about 10-15 seconds, turned the key, it would turn over, but as soon as I stopped turning the key the engine died. I got the manual out, and it said to crank for no more then 10 seconds. I did that, and it started up towards the end of 10 seconds and ran with no problem. During the summer, you turn the key for 1-2 seconds and it catches and starts up, even a few weeks ago when it was in the 20’s I had no problem. Did I just not turn the key and hold it long enough or do I have a problem??
Thanks in advance.
Tom
   / diesel wont start #14
Install a block heater/a timer. They are a lot cheaper than, batteries and starters. bcs
   / diesel wont start #15
<font color=blue>...about 15F and was very hard to start...</font color=blue>
Hi Tom,
This is just one of the characteristics with IDI Diesels being harder to start in cold weather vs. DI diesel...
<font color=blue>...Did I just not turn the key and hold it long enough ...</font color=blue>
I don't want you to go against the mfr. book/directions, but the colder the temps... the longer you will need glow plug preheat... I wouldn't hold it for 5 minutes (can burn the elements up)/w3tcompact/icons/sad.gif... but I'd try say 30-45 seconds (glow plug preheat) and bet it will fire up and catch... may be rough running for a minute or two... then it should smooth out...
Remember... the colder the ambient temps... the longer time for preheat you will need for startability... /w3tcompact/icons/smile.gif
   / diesel wont start #16
I agree with John, on my B7100 I turn and hold the key for preheat for at least 30 seconds if its below freezing.
   / diesel wont start #17
One thing you can do if fall else fails, is take a small propane torch, like you use for soldering, and heat the air going into the intake. Be sure to take out the air filter first. By putting heat into the box it should fire right up.
   / diesel wont start #18
I think before next winter I will add a block heater and not have to worry about it. Should have listen to the TBN folks, and not the dealer, when buying the tractor and just spent the $80 then. I guess I will see how much fun it is to get those plugs out of the block in the spring! I guess the project of running electric to the shed goes to the top of the list too!, I can just hear the CFO now...
Tom
   / diesel wont start #19
Agreed. One of the first things I did for my JD4600 was buy a both a block heater AND a hydraulic heater. Now I simply plug in the unit about an hour or so before I want to use the tractor and it starts like a champ (coldest test here in Minnesota so far has been about 8 below zero). Good use of $100 (including labor and both heaters) in my opinion and I'd recommend it to everyone.
One question though for those who might know when it comes to block heaters... should I leave the unit plugged in all night or is just wiser to plug it a couple hours prior to using the tractor?
Thanks!
-Bob
   / diesel wont start #20
<font color=blue>...I leave the unit plugged in all night or is just wiser to plug it a couple hours prior to using the tractor?...</font color=blue>
Well... if you have stock in the electric company... leave it plugged in all the time... /w3tcompact/icons/tongue.gif
...or buy a cheapo $5. electric timer and set it to come on, a few hours before your intended usage... /w3tcompact/icons/wink.gif
2008 Komatsu WB146-5 (A55272)
2008 Komatsu...
2013 Bell B35D Articulated Dump Truck (A59213)
2013 Bell B35D...
2018 John Deere 1653 (A56436)
2018 John Deere...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A58216)
TOYOTA 8FGCU30...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
