Diesel vs gas
/ Diesel vs gas #61
Please explain how that makes a difference?
If you don’t know the difference between a 1994-2003 port injected gasser of that era and a direct injected gasser now. Vs a 1994-2003 Tier I Diesel then vs a Tier IV diesel now . How can I explain it to you ?
/ Diesel vs gas #62
Duty cycle on Diesels are much lower than on gas motors.
The diesel can work half as hard to produce the same power, which is reflected in RPM's.
Diesels always win in this debate...
Please come up with some numbers to support your Straw Man argument that diesels work half as hard to make the same power .
/ Diesel vs gas #63
I would go diesel any day of the week, i own 6 diesel engines and would not take a gasser in place of any of them - they have their place
/ Diesel vs gas #64
Obviously YOU can't. :)
/ Diesel vs gas #65
Why should he, you didn't. :)
/ Diesel vs gas #66
Take two engines, gas and diesel, of the same displacement...say 6.0 liters each.
Say your target torque, ignoring HP for simplicity sake, is 300 Hp. The diesel can achieve this by only using 50% rated power and 2500 RPM. The gas can achieve this by having to use 90% rated power and 4500 RPM. Duty cycle is a generic term, but once you start calculating by engine load factors...you can see just what engine has to work harder to achieve the target torque for a given application.
/ Diesel vs gas #67
Well stated. That was my point 30 posts ago. Let the gasser dog pile begin. :)
/ Diesel vs gas #68
How does that explain these numbers from my IH owner's manual?
Pulled out my IH2500b manuals.
IH 2500b owner's manual said:
It was available with either a 200 cubic inch gas engine or a 239 cubic inch diesel engine.
With gears transmissions:
Full load engine speed for both engines is 2200 rpm.
High idle for the gas is 2420 rpm and the diesel is 2480 rpm.
With hydrostatic transmissions:
Full load engine speed for both engines is 2400 rpm.
High idle for the gas is 2640 rpm and the diesel is 2650.
The bore on the gas is 3.812 and diesel is 3.875.
Stroke is 4.39 gas and 5.06 diesel.
So, the diesel requires a larger bore and stroke and HIGHER rpms than the gas engine.
/ Diesel vs gas #69
diesel, i don't have to run my engines near as hard to get my work done and listen to screaming gas engines slurping fuel - for instance - growing up drove a 706 gasser for one particular farmer...........big gas engine, filled it up twice a day - that same farmer i worked for drove the 856 diesel, he only filled up every morning - i don't think his 856 worked near as hard, my ears were ringing every night from listening to that 706 scream all day but it never failed me it was just loud n thirsty, so when my wife hollers at me i say, HUH, don't forget honey i have tractor ears!!!
/ Diesel vs gas #70
I don't think there is enough info here to do a direct comparison. The cubic inches are different, and there is no rated Hp or Torque to make a projection load factor.
Fuel is one way to measure power, assuming stoichiometric fuel ratios and consumption rates, but I doubt IH has those figures accessible.
But you want an educated guess? The gas engine is using a whole lot of fuel to do what the diesel will do for far less. Beyond that, those two rotating assemblies are probably pretty equal in output.
Edit: Walked away and came back to reply, but ^^searcyfarms hit it right on.
/ Diesel vs gas #71
I've always been of the school that diesels pull better, are stronger, etc.... until I got to looking at this machine back in the early 90's. The numbers didn't add up, and the gas performed just as well as the larger diesel as far as output goes. Yes, it consumed a lot of fuel. Diesel cost more than gas at the time, but if you'd have gotten off-road diesel, it was pretty much even at the time. For me, the gas engine was a piece of cake to work on myself.
When I see people comparing gas engined tractors to diesel engined tractors, and then throwing in trucks, I like to look at the total cost of driving them both, and finding the break even point.
I found this calculator, where you can plug in the price of gas, gas MPG, diesel, diesel MPG, price per gallon of DEF, DEF MPG, the extra cost for the diesel engine option, and the miles it will take to break even. It was pretty interesting. I plugged in the numbers for my Suburban, and it was something like 450,000 miles before I'd break even.
Wish there was something like that for a tractor, but, since about no one sells a gas tractor, who cares? !! :laughing:
Gas vs Diesel – A Calculator and My Thoughts
/ Diesel vs gas #72
here is some hp/math for you, data from Nebraska Tractor Test 957 and 955 - closest i could find just right off 291 gas vs 310 diesel - the gas is smaller, used more fuel - both tested/rated engine speeds were 2300 rpm WOT, to produce the power of the diesel and get to a 5.0 gallon/hour fuel consumption you had to reduce the load on the gas engine by 50% - now what was the question............so to get the gasser to consume 5.0gal/hour you have to drop below 50hp, at 50 hp the diesel is only using 3.6+ so at 50hp i can assure you the gas engine is running more % of the WOT 2300 RPM and the diesel is purring much lower rpm as well as using less fuel - unfortunately NTT didn't use rpms on their graphs but i can tell you from old school math when the gas gauge said empty at noon it was out of HP and the diesel still had fuel and had plenty of HP to make it through the rest of the day ;-)
Type: 291 gas Torque Amplifier 2WD
PTO power (rated engine speed): 76.56 hp [57.1 kW]
PTO fuel use (engine speed): 6.3 gal/hour [23.8 l/hour]
PTO power (rated PTO speed): 71.8 hp [53.5 kW]
PTO fuel use (PTO speed): 5.8 gal/hour [22.0 l/hour]
Drawbar power (max): 65.67 hp [49.0 kW]
Drawbar fuel use (max): 6.3 gal/hour [23.8 l/hour]
Drawbar pull (max): 8,387 lbs [3804 kg]
then you have the diesel
Type: 310 diesel Torque Amplifier 2WD
PTO power (rated engine speed): 76.09 hp [56.7 kW]
PTO fuel use (engine speed): 5.0 gal/hour [18.9 l/hour]
PTO power (rated PTO speed): 71.84 hp [53.6 kW]
PTO fuel use (PTO speed): 4.7 gal/hour [17.8 l/hour]
Drawbar power (max): 67.46 hp [50.3 kW]
Drawbar fuel use (max): 5.0 gal/hour [18.9 l/hour]
Drawbar pull (max): 8,416 lbs [3817 kg]
Max pull gear: 3-Low-TA
/ Diesel vs gas #73
That's great! Consider at 14.7 lbs of boost a 6.0L engine will be displacing 12.0L of Air. I wonder how your 6.0 diesel would run naturally aspirated? If Deere put the GAS 50hp Chinese motor that is in their gators in a compact tractor, I'd buy one in a second!
/ Diesel vs gas #74
Well naturally, the diesel application would only need 1/2 the displacement (3.0), with 14.7 lbs of boost to get the same rated HP. With again, far less fuel to do the same job.
The law of physics, is the law of physics...can't change those. Duty cycles or load factors, what ever you want to call it, always has the diesel with the advantage when all aspects of power are looked at.
/ Diesel vs gas #75
25:1 compression? I doubt that more like 17:1.
As far as horsepower goes a gas engine of the same displacement will out perform a diesel. With tractors weight is not that critical so you slap a turbo on or just put in a larger engine.
The power curve of a diesel is also good for tractor work. If the engine gets loaded down and slows down there is still good torque at lower rpms where a gas engine falls on its face and will die.
Modern gasoline engines can have torque curves that shame a diesel's. It's just that that technology goes into Porsches, not Kubotas.
/ Diesel vs gas #76
Thanks! :thumbsup:
/ Diesel vs gas #78
Start out with both engines being the same rated HP or you are just comparing apples to oranges. Now for conversations sake compare a natural aspirated diesel vs a natural aspirated gas of the same displacement .
And what is the crime if the truck engine turns 4500rpm on a hill? It is not going to blowup or wear out any sooner . We are comparing light duty highway use vs HD applications such as marine propulsion or base load generator sets. Those are applications where engines operate at full load for months at a time and can easly rack up 6500+ hours a year.
My old 2003 pickup has 195,000 miles and the hourmeter is approx 6600hrs. The concerns regarding engine life have no merit . The body will be rusted off the frame before the engine fails.
In any case I can drop in a brand new long block cheaper than just a set of injectors and EGR repairs on a diesel .
/ Diesel vs gas #79
I have no idea why some of you drag up stories of the 1960痴 when gassers had carbs, points and diesels had just a mechanical injection pump . When diesel cost about 2/3 hat of gas.
Take a look over at the calendar on the wall. Brace yourself for the shock Rip Van Winkle it is July 2018.
Can you think of any differences regarding 2018 gasoline and 2018 Diesel engines ?
/ Diesel vs gas #80
That is a slanted comparison and you know it .
Compare both tractor engines at 100% power and compare both engines at 50%power . Your diesel at part load is now looking lousy with it’s HP per pound of fuel per hour vs the gas.
Now let’s get back to the reality of 2018 and light-media duty applications such as passenger vehicles , lawn/garden equipment, portable equipment , small construction equipment and off road recreational machines .
Due to the diesel costing as much or more than gasoline per gallon and Tier IV emissions . The diesel has been priced and strangled out of the light-medium duty market . If if was not for the fact that most of the rest of the world places luxury tax on gasoline to make it much more $$$ than diesel and does not have Tier IV emissions . The small Diesel engine would not exist and manufactures would stop building them .
1,000 gal Stainless Tender Tank (A66408)
1,000 gal...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2021 YANMAR VIO35-6A EXCAVATOR (A63276)
2021 YANMAR...
White 5100 4R Planter (A66408)
White 5100 4R...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
