Oil & Fuel Diesel Tractor belches smoke above 2000 RPM!
   / Diesel Tractor belches smoke above 2000 RPM! #1
KennK
NE Wisconsin
John Deere 3320
My fairly new JD 3320 started belching smoke out of the exhaust and stumbling whenever I try running it above 2000 RPM!
I've never had any problems with it previously. My first thought is to check the air filter(s) to make sure they are not clogged by critters or dust. I didn't check last night since the skeeters were so bad I couldn't stand them. I'll check tomorrow midday.
Any other ideas of what could cause the stumbling and smoke?
   / Diesel Tractor belches smoke above 2000 RPM! #2
Only two things cause BLACK smoke in a diesel: Too much fuel and/or not enough air.
Not only check the air filter, but you may want to remove any duct/hose to & from the filter to the engine & give it a look also.
If all checks out well, it may be time for a rebuild of the injectors (depending on what type of fuel delivery system is used).
   / Diesel Tractor belches smoke above 2000 RPM! #3
Sticking injector? Try running some injector cleaner for awhile.
larry
Well, I put in a new air filter, checked all the air passages (clean), and put on a new fuel filter. It still sputters with lots of smoke.
John Deere dealer is picking it up on Wednesday. Sigh!
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
