Oil & Fuel Diesel Tractor belches smoke above 2000 RPM!
   / Diesel Tractor belches smoke above 2000 RPM! #1
KennK
NE Wisconsin
John Deere 3320
My fairly new JD 3320 started belching smoke out of the exhaust and stumbling whenever I try running it above 2000 RPM!
I've never had any problems with it previously. My first thought is to check the air filter(s) to make sure they are not clogged by critters or dust. I didn't check last night since the skeeters were so bad I couldn't stand them. I'll check tomorrow midday.
Any other ideas of what could cause the stumbling and smoke?
   / Diesel Tractor belches smoke above 2000 RPM! #2
Only two things cause BLACK smoke in a diesel: Too much fuel and/or not enough air.
Not only check the air filter, but you may want to remove any duct/hose to & from the filter to the engine & give it a look also.
If all checks out well, it may be time for a rebuild of the injectors (depending on what type of fuel delivery system is used).
   / Diesel Tractor belches smoke above 2000 RPM! #3
Sticking injector? Try running some injector cleaner for awhile.
larry
Well, I put in a new air filter, checked all the air passages (clean), and put on a new fuel filter. It still sputters with lots of smoke.
John Deere dealer is picking it up on Wednesday. Sigh!
2018 Kubota M5-111 (A50123)
2018 Kubota M5-111...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2016 WACKER NEUSON LTV6 PORTABLE LIGHT TOWER (A51247)
2016 WACKER NEUSON...
