Oil & Fuel Diesel torque difference mostly myth?
   / Diesel torque difference mostly myth? #11
Another distinction is that the diesel will produce much greater torque throughout a much broader range of RPM's, while the gas engine needs to be at higher RPM's constantly to generate it's torque.
   / Diesel torque difference mostly myth? #12
Just an observation here. You guys can debate all the technical aspects of this until all of Getut's coworkers fall asleep from bordem, or you can do it my way, sell tickets to the event to raise money for charity (or just to pay for the beer), and all have a lot of fun (er, all but one guy I suppose) /forums/images/graemlins/blush.gif
JMHO
   / Diesel torque difference mostly myth? #13
<font color="blue"> On the exact same engine the higher the RPM and/or the higher the compression, the shorter the lifespan will be. </font>
On the exact same engine, everything will be the same -- inlcuding the type of fuel. You are trying to do an orange to orange comparison with an orange and a persimmon. /forums/images/graemlins/blush.gif
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Wow.. typing statements bite and oh how you can be misunderstood.
That statement was not differentiating between fuel types.. it was simply stating that on a given engine... any engine, the higher RPM and/or compression it is running at, the less its lifespan will be.
   / Diesel torque difference mostly myth? #15
   / Diesel torque difference mostly myth? #16
<font color="blue"> Another distinction is that the diesel will produce much greater torque throughout a much broader range of RPM's, while the gas engine needs to be at higher RPM's constantly to generate it's torque. </font>
Somewhere from the cobwebs of my mind, I remember reading an article about this very point. As I recall, one way to do the comparison was to compare the area of the graph under the torque curves -- or was it the HP curves. Hmmm, it seems I forget which it was. /forums/images/graemlins/confused.gif
Must be getting old. /forums/images/graemlins/mad.gif /forums/images/graemlins/grin.gif
   / Diesel torque difference mostly myth? #18
I'd say there's a slight difference in torque on trucks at least /forums/images/graemlins/wink.gif Using a 6.0 GM 'Vortec' gas engine compared to a 6.0 Ford 'Powerstroke' diesel. Diesel wins by far...
Horsepower (SAE net@rpm)
6.0L GM GAS = 300@5,000
6.0L FORD DIESEL = 325@3,300
Torque (lb.-ft.@rpm)
6.0L GM GAS ENGINE = 365@3,750
6.0L FORD DIESEL = 570@2,000
Wow Skypup.. you seem to be taking this personally.
I did not say gas was superior. I said diesel still wins.
But the normally aspirated, small diesels, with short stroke and high RPM do not have nearly as big an advantage as one normally thinks when they hear diesel. In fact, the small advantage that is left is only due to the higher compression and slightly higher potential energy per ounce in diesel fuel vs. gas.
You keep changing the scope of what I am saying.
PZ... you are correct, but look deeper. I guarantee you that even though the displacement is the same, I bet the stroke on the diesel is much longer than the gas engine.
I am talking about the nullifying effect of building the small diesels with short stroke that turn nearly the same RPM as their gas counterparts. The torque advantage is very small and is the basis for me starting this thread (and wanting to discuss it).
Flat Bottom Grapple (A56857)
Flat Bottom...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
More info coming soon! (A55851)
More info coming...
