Diesel storage ?
   / Diesel storage ? #1
zjohnson
West Tn
Ford 1920/MF 1130/ Ford 8N/New MF 491!
Could one use a polyethelene tank designed for "chemicals" for fuel storage? They are cheaper than metal tanks.
   / Diesel storage ? #2
How much do you really need to store? I've had my L3710 for 6+ years and the ZD21 for 2 and I get by with 2 5 gallon jugs. I average about 120 hours a year between the 2 machines and that's well under 10 gallons a month. I know the fuel is always fresh and conditioned in the winter. If I was running a farm and burning 100's of gallons a month I'd have a storage tank.
   / Diesel storage ? #3
I agree, unless you need large quantities, try to avoid storing it. The fresher the fuel the better.
Steel tanks are a bad idea due to the condensation and rust concerns. If you need alot of fuel on hand you'd be better off with the plastic tank. Storage is the #1 reson behind diesel drivability issues.
   / Diesel storage ? #4
</font><font color="blue" class="small">( Could one use a polyethelene tank designed for "chemicals" for fuel storage? They are cheaper than metal tanks. )</font>
I'm currently using a 275 gallon "storage tote" which I picked up for $50 from my fuel supplier. It was originally used to store/ship bulk hydraulic fluid. So the answer is yes, you can.
   / Diesel storage ?
Thanks for the replies! I use about a hundred to hundred twenty five gallons a year and want to buy in 100 gal lots to save a little $.
   / Diesel storage ? #6
I would recomend against having a years supply. It will begin to separate and grow contaminates unless you have a controled environment for it to stay and an agitator to keep it from settling.
   / Diesel storage ? #7
</font><font color="blue" class="small">( Thanks for the replies! I use about a hundred to hundred twenty five gallons a year and want to buy in 100 gal lots to save a little $. )</font>
Thats what I've been doing going on 3 years now. The guy I work with has been doing the same thing for at least 15+ years. No problems using a 300 gal steel tank stored outdoors. We both add PowerService to the mix. He changes the filter every year, I haven't change mine. Any crud/water will settle in the bottom of the filter bowl or get trapped in the filter.
   / Diesel storage ? #8
There are many reasons why storing fuel is not a good idea, not the least of which is that you make an inviting target for a thief, fuel prices being what they are.
   / Diesel storage ? #9
How much is "save a little $"?
You have to consider the cost of the storage equipment and the risk of storage and this may offset the savings.
I use my tractor about 300 hours a year, which amounts to around 300 gallons. I always have the tractor full (15 gallons) and have two 5 gallon containers. This works fine for me.
Richard
   / Diesel storage ? #10
</font><font color="blue" class="small">( How much is "save a little $"?
You have to consider the cost of the storage equipment and the risk of storage and this may offset the savings. )</font>
True - most likely the added will have to be amortized over a number of years to see any real savings - however there's also the convience factor to consider, which may not be a small thing. For me, not having to run out for fuel is a big attraction - I've been very busy with projects this summer and have put around 250 hours on my tractor so far this year - that's about 32 trips to the station with a 5 gallon can - or 16 if I use two. It's real nice to be able just to pull up to the garage and fuel up.
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
Knight 1040 Manure Spreader (A50774)
Knight 1040 Manure...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
