Diesel storage tank, pump, filter and water separator. Which order?
   / Diesel storage tank, pump, filter and water separator. Which order? #1
rogersmithiii
Hardwick, MA
Gravely 16G / Deere 310 L
What is the order if you are installing a storage tank. a Fill-rite pump, a cartridge filter and a water separator? Do the filters go between the tank and the pump, or the pump and the nozzle? Any order on the filters?
   / Diesel storage tank, pump, filter and water separator. Which order? #2
My setup has a pump going into a combo filter/separator then out to the hose and nozzle.
   / Diesel storage tank, pump, filter and water separator. Which order? #3
If all separate: pump, filter, separator. In 39 years of running diesel cars, 17 years running diesel tractors and now 8 years running a diesel generator, I've never ever had a water in diesel problem.
   / Diesel storage tank, pump, filter and water separator. Which order? #4
Tank>Pump> T-block> water separator filter combo> hose> auto shut off nozzle
   / Diesel storage tank, pump, filter and water separator. Which order? #5
Been storing diesel in two 55 gallon vented drums kept under a shelter for 6 years in humid N. FL. My fuel supplier has a filter on the truck as does any pump you buy fuel from a station does. I don't filter at all before pumping into the tractors. My pickup tube is off the bottom so I have 5 gallons left when it won't pick up any more fuel. When it gets to that point I tilt the drum and pull the remaining 5 gallons for inspection. Never had an ounce of water.
   / Diesel storage tank, pump, filter and water separator. Which order? #6
If you have your suction pipe appropriately high enough off the bottom, a water seperator or absorbing element is a moot point. You expect water to be in the bottom of any large long term storage bulk tanks. Just have a drain on the bottom, and drain it when paste shows that it's worthwhile.
I had a Panic when all my stuff started to run like crap and went buying filters and seperators for the bulk tank. When all that happened is that I screwed up and switched pumps putting one with a longer suction pipe into a tank, thus sucking all the water and crap off the bottom.
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
