Oil & Fuel Diesel running backwards
   / Diesel running backwards
Rat
The reason the motor ran backwards for one minutes my wife was driving it when it happened. I was about 250 yards away when it happened. She was turning around in the woods when she got up against a tree and almost stalled it. She couldn't figure out why the tractor wouldn't move with the motor running and was fiddling around with the pedals. By the time I could get there with one bad leg, it took me over a minute.
The tractor is back at the dealer right now and I could not make it run backwards either but when we lugged it down a little it would kill the motor every time. Even the dealer service manager and the JD factor rep. said they wouldn't except that on there tractor but that is the nature of the beast. We tried two other 4700 HST and they did the same thing but when we tried the 4300 HST It worked fine. I think the 4700 would work great for mowing grass but when you start pulling stumps and logs and digging big boulders it's the wrong machine. I had the dealer try to pull another tractor and when we hit the breaks a little he let off the pedal it stalled out every time. I don’t know if all HST tranys do that I have never owned one before. John Deere rep is still trying to figure out if there is anymore they can do to help make it work better.
Dan
   / Diesel running backwards #12
I agree with your point of shuting the engine down when it begins to run backwards. However JD should do something to correct this problem considering the cost of the tractor. I ordered a 4700 HST for my local JD dealer 4/7/01 and I hope to take delivery this week. I will definatly be talking to the dealer about this issue before I take delivery.
I have owned numerous Ford/N.H. tractors over the years(5030,1700,1715,6635) and never had this event occur. This is my first try with a JD. I hope I made the right choice.
   / Diesel running backwards #14
I thought they had fixed this somewhere in 1958 on the JD 720 two-cylinder diesels by installation of a cam which prevented it from running backwards. There are some funny stories out there referring to 720's with 6 gears in reverse, one forward. An inexperienced operator can do this to an old 720, most typically at a tractor pull, when the last stroke of power is being extracted. It's not a good thing for a diesel engine.
   / Diesel running backwards #15
Hi
This is Chaman From India
I have reversing problem in Haulage truck application
Symptoms are same like you.
But this is not observed in VE / Rotary FIP's
Rat
The tractor is back at the dealer right now and I could not make it run backwards either but when we lugged it down a little it would kill the motor every time. Even the dealer service manager and the JD factor rep. said they wouldn't except that on there tractor but that is the nature of the beast. We tried two other 4700 HST and they did the same thing but when we tried the 4300 HST It worked fine. I think the 4700 would work great for mowing grass but when you start pulling stumps and logs and digging big boulders it's the wrong machine. I had the dealer try to pull another tractor and when we hit the breaks a little he let off the pedal it stalled out every time. I don稚 know if all HST tranys do that I have never owned one before. John Deere rep is still trying to figure out if there is anymore they can do to help make it work better.
Dan
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
light tower (A56857)
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2019 Grove TMS500-2 40T Crane (A60460)
2019 Grove...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
