Diesel question
   / Diesel question #21
I run the lowest rpm's that I can get the job done with without creating black smoke. That's usually 1,100-1,500 rpm's for general loader work, 2,000-2,500 for required PTO speed work like the chipper, and snow blower. If you're puffing continuous black smoke, you aren't combusting well and need to drop a gear and bring up the revs to make more HP.
But for sure, for almost all tasks, lower rpm's burn less fuel, and that's a good thing
   / Diesel question #23
You might want to think about using a break in oil (with your dealer's blessing) since you aren't working it hard enough.
   / Diesel question #24
Hmmm---- What I do with the tractor will naturally dictate the rpm. Except for the first 50 hours - this will mean higher rpm when I use the chipper, when blading deep snow on the driveway or plowing. Otherwise, its usually 1500-1900 rpm for the grapple, land plane, farm wagon or roll-over box blade. I've never had oil consumption between any oil changes. I use standard Kubota dino oil all the time.
KODIAK 6' ROTARY MOWER (A52708)
KODIAK 6' ROTARY...
2008 International Bucket Truck (A55973)
2008 International...
2013 ISUZU NPR STAKE BODY TRUCK (A58017)
2013 ISUZU NPR...
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Ford F-150 (A56858)
Ford F-150 (A56858)
