Oil & Fuel Diesel Kleen fuel additive
   / Diesel Kleen fuel additive #1
ToJo
AL
Kubota L3400 FEL
Has anyone ever used Diesel Kleen fuel additive? I picked up a quart at Wal Mart and read the label. It is supposed to be a good fuel stabilizer , plus, it is supposed to raise your octane rating from 3 to 6 points depending on how much you want to put in it. It is also supposed to keep the fuel system clean, eliminate water in the fuel, lubricate better, etc. Sounds like good stuff.
   / Diesel Kleen fuel additive #2
can't really tell you if that stuff is any good! But why do you feel you need it? what additives do you add to the fuel for you car ?
   / Diesel Kleen fuel additive #4
</font><font color="blue" class="small">( Has anyone ever used Diesel Kleen fuel additive? )</font>
I've been using it for 4 years in my Passat TDi. I've actually documented a slight drop in mileage when I "forget" to add it to the tank. Good stuff IMO...
Patrick
   / Diesel Kleen fuel additive #5
I've been using it in my VW TDI turbodiesels for eight years now, also using it in our 1985 Massey Ferguson 1030, Kubota L-3130, Kubota ZD-21, and Kubota L39. Excellent lubricant for the injection pumps and injectors as well as fuel enhancer.
BTW, it increases the cetane level by adding 2-ethylhexylnitrate, not the octane level. /forums/images/graemlins/wink.gif
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
BOBCAT T595 LOT NUMBER 153 (A53084)
BOBCAT T595 LOT...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
