Diesel Kiki Fuel Injector Pump for Hinomoto E16
   / Diesel Kiki Fuel Injector Pump for Hinomoto E16 #1
dedpossum
Hinomoto e16 2wd
Hello!
A friend of mine gifted me a Hinomoto e16. He said that there was a problem with the injector pump. The motor is 2 cyl. I am in the process of trying to locate a manual of some sort, or any information for this pump. My first question: Is this pump supposed to have oil in it? Second is there anywhere on God's green earth where a new pump and/or parts could be located?
Thanks in advance!
   / Diesel Kiki Fuel Injector Pump for Hinomoto E16 #2
Yes, the pump is supposed to have oil in it..
Your pic doesn’t show enough of the gov to tell if u have the full or drain screws.
Some do and some don’t..
On the back side of the pump there should be a vent pipe.. it will dump anything over the intended amount..
so there’s no worries of over filling it..1/2 qt should be fine.. use the same oil that’s in the tractor..
before u ask, I don’t sell parts..
AND IF your thinking of taking it off .. U HAVE TO TIME IT FIRST..
Good luck
Awesome! Thank you very much! You seem to understand these things any chance you know where a diagram/specs for this bad boy is?
Thanks again for the info!
Aaron
   / Diesel Kiki Fuel Injector Pump for Hinomoto E16 #4
Sorry.. all that info is stored in that round thing that sits between my shoulders..
Well, I have the engine at TDC and pulled the injector pump. Gonna start going through it. Wish me luck!! Any ideas where to get gaskets and what not for the rebuild?
   / Diesel Kiki Fuel Injector Pump for Hinomoto E16 #6
B careful when u remove the back cover.. it’s spring loaded and there’s shims on each side of the spring..
IDK what your going to do once u get the cover off, u need special tools to go any further..
Thanks for the heads up! What special tools would I need? My thinking is the tractor doesn't run with out the fuel injection pump, the fuel injector pump isn't opening the valves at all let alone in time. I can't seem to find even a picture of the pump let alone a replacement or even a whisper of a replacement part. So really what do I have to lose?
   / Diesel Kiki Fuel Injector Pump for Hinomoto E16 #8
An injection pump is considered an “emissions device”.. therefore not open to public information..
It’s a specialized trained group of people that are factory trained and pay for the privilege for the information necessary to repair these pumps..
I’m not gonna tell u u can’t take it apart w a hammer and screwdriver... but getting it back together and it in running condition is gonna b tough.. real tough..
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
