Diesel in oil?
   / Diesel in oil? #1
sierradmax
1998 Bobcat 763 & 2009 S-175
Under routine maintenece on my 763, I noticed the oil level on the dipstick was quite high. In addition, the oil appeared to be very thin. It's either antifreeze or fuel.
I drained the engine and placed in a clear jug. I didn't see any seperation which makes me believe its fuel. Hwoever, is there a definite way to tell? The machine still runs fine but I'm scared to run it any longer as the oil thins out even more. Besides fuel leaking into the cylinder or bad rings, where else can fuel leak into the motor?
   / Diesel in oil? #2
Check the fuel injector pump seal. Neighbor had to rebuild his JD with this issue. Mechanic told him the injector pump seal failed allowing fuel into the crankcase.
   / Diesel in oil? #3
This happened to me several years ago with my JD 820. The mechanical fuel pump diaphragm ruptured, allowing fuel to enter the crankcase. Replaced the fuel pump and problem was solved. I would definitely check this out before you get involved with the injector pump.
   / Diesel in oil? #4
The diaphragm/lift pump would be first palce to check for fuel in oil. If is was anti-freeze it should settle out in your sample jar plus the wohuls be other indications such as loss of coolant, constant bubbles in over flow bottle, and probably some smoke due to blown head gasket or cracked head.
(4) 5 LUG WHEELS & TIRES (A51248)
(4) 5 LUG WHEELS &...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
8ft Fork Extensions (A51691)
8ft Fork...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
