Diesel IH 464 throwing watery oil out overflow.
   / Diesel IH 464 throwing watery oil out overflow. #1
ENR
Kubota Kx-033R
I was running 10-30 oil after an oil change and it started throwing watery looking oil from what I think is an overflow tube on the right side of the engine. Realized that the owner manual says specifically do not use 10-30. Drained and changed filter and used straight 30 weight per owner manual. When I check oil level after warming up, it appears overfilled. There is oil about halfway up the check/fill tube. I put in stated capacity of 7 qts. Engine temp remains good when running hard. I am perplexed. Questions: How can than there be so much fluid in the crankcase? Why does it appear to be watery? Thanks for any ideas.
   / Diesel IH 464 throwing watery oil out overflow. #2
When you say watery does it look milky in color or just really thin?
   / Diesel IH 464 throwing watery oil out overflow. #3
How does your radiator level look?
   / Diesel IH 464 throwing watery oil out overflow. #4
What does the dipstick read after before starting the engine.
If it reads over full, by how much.
If the oil still looks like oil how does it small, like diesel?
   / Diesel IH 464 throwing watery oil out overflow. #5
10w30 is pretty much the same as 30 weight. Think 30 weight is probably 15w30.
You've probably a head gasket leak.
   / Diesel IH 464 throwing watery oil out overflow. #6
When you changed the oil...
added 7 qts....
You checked the dipstick level after this, what did it read then?
How much time on the oil before you rechecked it and it was 1/2 way up the dipstick?
What did the dipstick read before you changed the oil again?
   / Diesel IH 464 throwing watery oil out overflow. #7
How is hyd pump mounted?
   / Diesel IH 464 throwing watery oil out overflow. #8
lots of great suggestions in here, some are more subtle than others. I guess first step is to find out what is in the oil, water or hydraulic fluid. check all fluid levels and make a note of which ones are higher and which ones are lower.
   / Diesel IH 464 throwing watery oil out overflow. #10
Ok not milky but thin and seems to be making more. Does it smell like diesel? Fuel lift (primer pumps) are bad about leaking fuel into crankcase as the diaphram ages.
Since its not a milky emergency, buy an oil scan kit and see what is in it before you start changing parts.
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2016 Nissan Versa SV Sedan (A53117)
2016 Nissan Versa...
Mini trencher attachment (A53421)
Mini trencher...
Hose Reel (A53424)
Hose Reel (A53424)
2013 Ford F-350 Pickup Truck (A53117)
2013 Ford F-350...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
