Diesel hard to start, boggs down,quits running
   / Diesel hard to start, boggs down,quits running #11
First of all you need heat to explode diesel mist. Heat comes from high compression and high starting rpms. Low voltage to the starter won't give you the necessary rpms to get going in a timely manner. It (the electrical system) has nothing to do with your diesel after it's running and certainly is not part of your "stops 20 minutes down the line". Diesels run on fuel, compression, and correct timing. Remove one and it stops....that simple . No electricity, no static, no radio interference, no battery (once started) all that sparkie stuff.
If you are having hard starting issues you have to have a fully charged battery, CCA of adequate size and battery with the capability to deliver it with low internal resistance, and all connections (including the cables and crimped on lugs) between the starter terminals, the stud and the case, have to be shiny (inside where the current flows) and tight. If you have 10 V at your starter when cranking you have a good system. Anything less and you have a loafer somewhere in what I mentioned above.
Can't think you for all the info. Needless to say I'm new at Diesels ( and tractors) Have all the shop manuals , willing to learn and try but there is no replacement for experience and that, you all have. I'll double check all connections and voltage. I believe that a new 1000 CCA battery should be adequate..though I will check the manuals. You don't think it is a compression issue? I don't...seems it would not have started before. Now it's been down 2 weeks.
I'll give it a shot and post back...thanks for your patience
Cravyhorsemd
OK ALL...Still working on it Here we go
Changed, removed , cleaned all fuel delivery filters....replaced lift pump, replaced fuel, bled system ..replaced (-) lead with 0 gauge, even doubled (+) connection to starter solenoid (Had 2 #2 leads so I connected them to make darn sure all power got to starter) checked replaced all fuses and cleaned terminals. NOW...engine turns over quicker..white smoke from stack, appears to "want" to start but doesn't fire. But..as before after 4-5 attempts I need to jump the battery to supply enough power...the battery just runs out of juice. Leave on jumper after 5-10 minutes then get enough to try again. I'm starting to think compression issue but have no way to check. In the past (winter) a "shot" of ether worked, didn't use a lot and only rarely but now it doesn't help.
   / Diesel hard to start, boggs down,quits running #14
If you bought the tractor and it always had a hard time starting you may want to have the starter checked out. I had a similar experience when I got my tractor it started hard and I went through the same pain new battery crank a few times and jump. When I finally replaced the starter I could not believe how the new one turned the motor over it was night and day different. Never had a starting issue since, I know this won't help the 15-20 min run time but maybe a good idea to pull the starter and have it checked out.
   / Diesel hard to start, boggs down,quits running #15
You are getting combustion with the visible white smoke which is moisture which accumulates as a byproduct of combustion in a cold environment. You have to spin her up to get the heat needed to explode the diesel mist. She's trying but you aren't quite there yet. Really, you shouldn't have to run down your battery to get your tractor started. I'd find out how to and find a tester and start with a compression test. A 15:1 compression ratio should be enough, so 15x14.7=220 psi minimum with all injectors and air intake filtering removed, fully charged battery. If you pass that test then start looking elsewhere for problems; injectors clogged, fuel restricted, clogged air intake, timing retarded due to wear on the engine/pump gears, pump pressure/injector pressure popoff low failing to properly mist fuel.
Still at it.....
Three questions:
1. could the injector pump get off timing without taking it off or apart? I keep reading so much about injector timing issues and it seems that some are implying that it can.
2. Fuel return lines.. The thermastarter bowl is not filling from the return line. Possibly since it is not running enough or blockage. Would blockage cause any of these issues, starting / running / bogging down and quitting?
3. Plan to have starter tested.. If bad, would anyone recommend a Gear reduction starter vs regular. Seems the gear reduction would give more torque and spin for less power required.
don't mean to be a pain, just want to exhaust options before paying out the rear.
   / Diesel hard to start, boggs down,quits running #17
You've got a couple issues going on here.
First is your starting issue. I'd pull the started and look to clean it up: sometimes that's all that's needed- they tend to get gunked up, grease on bushes try up and the thing just binds. Probably best to take this on a step-by-step basis and do a voltage drop test first, as this would tell you if the starter is in fact drawing more power than it should: but if the starter hasn't never been touched and it's easy to remove I'd just do it to get that checked off the "done" list).
Second issue, and the bigger problem, is why your engine is stopping after it's been running for several minutes. I highly doubt that your timing is managing to shift consistently to cause this in the repeatable fashion that it sounds like you're experiencing. This has all the marks of it being a fueling issue. I'd take a vacuum pump and do a fuel draw back to the tank to see how hard fuel is pulling. If it seems OK then move on. If it doesn't seem OK then look for blockages: debris in the tank CAN be somewhat consistent in reorienting itself into the stream causing blockage- I recently experienced this with my new tractor, though it ended up being water (ice chunks kept pulling into the tank outlet and shutting off fuel flow- in this case the engine would run only a few seconds and then die). If you have any sort of fuel shuttoff (as most diesels tend to, though what kind it may be I cannot say) I'd check that that's operating properly: could be a bad wire that causes a voltage drop or the like. Check over all fuel lines: soft lines can collapse.
If you have (good) fuel, have reasonable starter RPMs and you have air (assuming timing is close enough) then the engine fires and runs.
OK All,
it's been months since last wrote
Roll started diesel and finally got started after sitting for 4 months, ran for about 10 minutes then slowly lost power and died. Pumped lift pump 20-30 times, roll started again, ran 2-3 minutes again slowly lost power and died. This repeated several times. Now I'm thinking injector pump failure. Any thoughts???I have always felt that I had a fuel issue though could not any restrictions to fuel flow. When I pump lift pump a bunch and roll start it runs well. ?? fuel not getting to injector pump or not from injector pump. If latter the case then why does it run after using the lift pump.
Still, labors to start as before, as stated above, 1000 CCA battery, new wires, good connections battery turns over engine 4-5 times then really labors to turn over. Could a failing injector pump just not supply enough pressure to allow injectors to vaporize fuel correctly in order to start???
I'm not giving up
I'm going to get this solved
Thanks to all
Crazyhorsemd
   / Diesel hard to start, boggs down,quits running #19
Take the lift pump apart & inspect OR REPLACE.. they're only like 40.00..
Get the starter rebuilt or replaced.. plenty of options online..
IF you cant get fuel to it OR crank it, how are you going to diagnose a fuel problem??
Personally I would borrow/rent a compression tester BEFORE rebuilding or replacing ANYTHING..
Still at it....unfortunately but here goes
Keep thinking a fuel issue...Took off fuel tank, cleaned it out....not real dirty inside for 40 + years, replaced fuel lines, another set of fuel filters, rechecked all filter screens...clean. Bled system and got it started. Actually runs well , no knocking, odd noises, smoking .... It ran for 20 minutes then lost power and died. Unable to restart turns over a couple times but battery dies out. (Battery new 1000 CCA, multimeter test good) Sat overnight, restarted yesterday. ran good about 20 minutes then dies out < liked starved for fuel....again trying to restart, really seems like it doesn't want to turn over and battery dies after 4-5 attempts. No blow by when running. It kind of reminds me of Vapor lock on gas engines years ago...not sure if this happens to diesels an why now would this show up??? Only thing left is the injector pump. Does this sound like an injector pump issue? Neighbor stopped by when it was running and died, agrees that appeared like fuel issue. Also, new lift pump installed..after starting this issue no real difference..could be a bad one though??? (It installed easily...is there anything I need to know about installing one??? He did mention seeing small fuel drops occasionally about injector pump thought " if leaking somewhere possibly sucking air. Still doesn't explain why runs for 20 minutes , dies out then doesn't want to restart I AM NOT GIVING UP When it's running it throttles up well, runs smooth no smoke
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
UNUSED FUTURE AUGER SET (A58376)
UNUSED FUTURE...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
500 Gallon Fuel Tank (A57149)
500 Gallon Fuel...
CRATE OF MISC ELECTRICAL, POWER TOOLS, CART & MORE (A58376)
CRATE OF MISC...
