Diesel Generator or PTO Generator?
/ Diesel Generator or PTO Generator? #1
Olympus
Platinum Member
Cape Girardeau, MO
LS R3039
I'm trying to decide whether I need a good generator or not. I have a portable gas genny but it's loud and not big enough to run my whole home. I also have been moving away from gas and towards diesel. I now keep a 40 gallon barrel of diesel at all time. So a diesel genny makes more sense.
My question is whether I should get a PTO genny and use my tractor to power it or just get a complete portable diesel unit with engine and genny both. The PTO I'm looking at is 7200 watts rated and it's $900. The complete unit is 6500 watts rated for $1150.
I have two concerns with the PTO. My tractor is 23hp and for 540rpm that would require running at almost full throttle. I'm worried about that being hard on the tractor engine for extended periods line 5 to 7 hours at a time. My next concern is my tractor is brand new and I don't want to rack up lots of hours and wear my tractor out quickly.
My concern for the complete unit is whether 6500 watts will be enough for my whole home and also the additional worry about another engine to regularly maintain. I keep my tractor ready at all times and it always fires right up. I don't know if the complete unit would be the same.
Any advice would be appreciated. Been at the house 2 years and never had a power failure more than a couple hours, that's why I'm leaning toward the PTO since it's higher wattage and lower price and the need for usage may be little. We have buried utilities.
/ Diesel Generator or PTO Generator? #2
My first reaction is, if you have only lost power for a few hours over 2 years.... get some candles, a battery powered radio, 5 gallon pail for water if you are on a well and call it done. If you have medical needs to have power, then get the portable unit. I spent a lot of time debating the same thing, I decided to get a portable unit. If we are out of power long enough to bother to hook up the generator, there is a good chance I will need the tractor. I am away for 2 weeks a month and my wife can't hook up a pto generator to the tractor but she can start a portable unit. You need to sort out the wattage of your home, then decide what must you be able to run, then what would you like to run.. then that will tell you what size generator you will need.
/ Diesel Generator or PTO Generator? #3
I went through this routine a few years ago and decided I didn't want to tie the tractor up, plus the fact that I'd need to get the tractor from the shed to the house, in the event of an extended outage. I ended up getting a Home Depot [Ridgid] gas 10kW. I would have preferred diesel, but was too cheap to fork out that much $ just for a generator. Since that time I bought my first welder to learn and play with, and in hindsight, what I probably should have done was buy a good diesel welder and use it for a generator.
Have fun shopping. :)
- djb
/ Diesel Generator or PTO Generator? #4
There's lots of wattage calculators out there to size a gen. I prefer the minimum and ease of hookup so have a 4000w gas inverter unit that is electric start. The plus with the inverter is it runs at the speed needed for the draw which of course saves gas, it is also very quiet. I have town water so can live without having 220v. I have a 6 pole transfer switch with a plug near where the gen lives. I could easily talk the wife through setting it up via a phone. Personally, I would not want to tie up my tractor. You may want to look at propane ones also if you already have that at your house. There's many options in that realm and none of the gasoline issues.
/ Diesel Generator or PTO Generator? #5
A PTO generator will tie up your tractor but would run the whole house. I had a 5KW gas generator (6250 surge). It would run my whole house except the A/C window units. When I was looking to get a larger generator I also needed to replace my old AC buzz box welder. I don't have natural gas here and only a small propane tank for the cook stove so that ruled out a guardian generator for me. I figured I'd kill two birds with one stone and bought a Miller Bobcat 250 NT welder / generator. Its 10KW and will run my whole house including the A/C units plus it is a decent welder. Diesel generators are usually close to twice the price of gas powered ones.
/ Diesel Generator or PTO Generator? #6
I don't subscribe to the notion that 'it ties up your tractor'. How so ??? If you need the tractor, disconnect from the alternator and take care of business. I actually have both types of systems and the tractor hook up is easiest. My Winpower is always parked at the disconnect. In Winter, you need water and heat and maybe some cooking. In Summer, you need water and A/C and food. So hookup, run the furnace to get the temps adjusted, fix dinner and then take the tractor into town for some beer and pretzels. If your house looses all its heat within 30 minutes, put the axles and wheels back on and move it south.
But is it tied up ? No way. If it takes more than a minute to disconnect or reconnect your temporary power you need more help than a tractor or a generator standing by....
/ Diesel Generator or PTO Generator? #7
I guess it depends on how he uses his tractor. If it just sits parked most of the time then using it to power a PTO generator would not be a problem and not really tie it up. But if he uses the tractor for farm work and its the only one he has then it would be tied up using it to power the house or barn when he needed it for other jobs.
/ Diesel Generator or PTO Generator? #8
Yeh, pitch black ,cold house in the middle of a raging snow storm. To prevent that... some would call that having the tractor "tied up"...
/ Diesel Generator or PTO Generator? #9
I was concerned about the tractor being unavailable in bad weather (snow) since I use it to snowblow 6/10 of a mile driveway. I started with a small gas, then a 7KW gas gen. With a diesel tractor I rarely kept fresh gas around, which became a concern. Knowing that diesel has a nearly unlimited shelf life, I next upgraded to a 2 cyl, 3600 RPM Duetz aircooled diesel, rated at 8 KW. Ran well, but loud and it was tough starting mid winter. I last upgraded to a 9.8KW kubota driven water cooled 1800 RPM unit. Maybe overkill, but it uses common filters, etc as my tractor. I must say it is relatively quiet, powers the whole house, summer and winter, and on average uses 0.3 g/hr with AC or heat running. I have a 50 gal tank dedicated to the genset and another 50 gal for the tractor. Several years old and no regrets.
paul
/ Diesel Generator or PTO Generator? #10
I certainly would.
If people need a generator to power their house the entire time electricity is out, then it's not a 'notion to be subscribed to', it's a requirement.
/ Diesel Generator or PTO Generator? #11
Either type of generator will need to be tested periodically, but stand-alone more than pto since presumably, you know your tractor will start when needed.
Personally, I would be more likely to faithfully do that testing with a stand-alone set compared to hooking up the tractor pto.
Your power does sound very stable. If you aren't in a location that could see long outages from storms causing wide-spread damage, the advice to consider your actual needs is worth considering. You might be driving a tack with a sledge hammer.
My tractor doesn't get used much except to bush hog. It would not be tied up to use for a gen.
A standby generator is twice as high as a diesel and that's not counting installation and running a new gas line.
/ Diesel Generator or PTO Generator? #13
In all honesty, how long has your longest power outrage been? I am 100% electric and in the 32 years I've been out here the longest outage was about 14 hours. Unless you have some medical condition - you can easily survive a 14 hour power outage without a generator. Your food in the freezer will still be frozen rock hard after 14 hours and everything in the refrigerator will still be perfectly edible. Unless you have some very unreliable electric supplier, the generator will see most of its time running just to keep it prepared for an outage.
If you still feel a generator is necessary - be certain you use a reliable calculator to figure the size you need and for goodness sake be certain to contact your electric company so they can inspect the interconnect you will have to install. Be sure to check with a reputable electrician so he can give you an estimate of the cost of the interconnect and cost to install - you will be surprised!!
/ Diesel Generator or PTO Generator? #14
Are you going to have your tractor parked where the generator is? Besides having the tractor tied up with a generator, I didn't like the idea of trudging out to the tractor shed in foul weather (rain, mud, etc.) and moving the tractor to where the generator is located. Plus, during heavy rains, our property gets pretty soft (east Texas prairie gumbo), and that's when I'd be trying to move the tractor around.
Nah, I decided to just have a generator in place ready to run. All I gotta do is start it up. :)
Everyone's situation will be different.
- djb
My shop is directly across the chat driveway from the house. The gen would be stored in the same shop as the tractor. Hook up the gen before leaving the shop. I can get a bigger gen by going PTO as opposed to a complete unit.
/ Diesel Generator or PTO Generator? #16
Went through the same dilemma as the OP a few years ago. Here in No. VA we have pretty reliable power, but we lost it for four days from the June 2012 derecho. Was real glad to have a dedicated portable gas generator, 8250 watts. With so much tree damage, we needed our tractor a lot, and in 95 degree heat, we also needed power for the fans, 400 ft. deep well pump, freezers, fridges and TV for the news and weather. Can't power our AC units with that size gen set, but that's just an inconvenience. During "Snowmaggeddon" in February 2010, we lost power for three days and needed the tractor even more, to clear the mile-long driveway that serves us and some neighbors. Now that we've added another tractor, we could use the smaller one for a pto generator, but I still much prefer wheeling out the portable and pushing the start button. Especially if it's in the dark with a flashlight. :)
Definitely see your point there. Problem is a 13kw PTO gen is $1400 and a 12kw GAS portable is $2100. If such were the that I needed the tractor, I'd unhook from the gen and do the necessary work and then hook back up again to gen. I would not need constant genning power 24/7.
And seeing that I keep amble diesel available, a portable diesel that size is way up there. I don't want or need to keep a large amount of gasoline.
/ Diesel Generator or PTO Generator? #18
Probably 10 years ago I bought a 12kw pto generator because every time we got a 30mph wind we would lose power. I used it 2 hours in those 10 years. Then during the Christmas holiday in 2013 our county was hit with a nasty ice storm. 90+ % of the county lost power. We were out of power for almost a week. Glad I had the generator. Had to take it to Mom and Dads for Christmas because they have an electric stove/oven and their generator couldn't handle it and Mom was trying to make Christmas dinner. If you don't have electric heat, hot water, AC, or electric stove/oven then the size you are looking at is probably fine. Otherwise I'd go for at least 10 to 12 kw.
/ Diesel Generator or PTO Generator? #19
Do you really need to power the entire house during an extended emergency outage? We do well with a 3000 watt quiet Honda. We used to have a 6K+ noisy generator and wouldn't use it because of the noise. I gave it to my son.
If you have a standalone unit, make sure to keep the starting battery in good condition. Our 3000 watt Honda's battery was dead during our last outage, it had been a few months since I had run it. Fortunately, it has a backup pull start and started on the first pull.
For the price difference the OP quoted, I would go with a standalone unit and not have to fool around hooking it up to the tractor.
OTOH, I wouldn't worry about "wearing out the tractor", most tractor engines are made for hours and hours of running at 540 pto speed.
Another thing to consider is the noise level between the tractor and a standalone unit.
I do love the inverter type generators. They are generally quieter and throttle back the engine with smaller loads and save on fuel. 40 gallons of fuel will not last long during an extended outage. If you are out of power for a week, finding fuel locally may be impossible if the outage is widespread. A gallon of fuel per hour will take more than 40 gallons in two days alone.
As for cost, don't overlook the cost of a whole house transfer switch and having it installed. That may cost as much as the generator. Currently, I still use extension cords when we have a power outage. One of these days, I will get a 10 circuit version of this transfer switch
Amazon.com : Reliance Controls 31406CRK Pro/Tran 6-Circuit 30 Amp Generator Transfer Switch Kit With Transfer Switch, 10-Foot Power Cord, And Power Inlet Box For Up To 7, 500-Watt Generators : Manual Transfer Switch : Patio, Lawn & Garden
/ Diesel Generator or PTO Generator? #20
I'm glad you brought that up! Using cords, or installing a proper transfer switch, is the way to go.
I have the transfer switch you mentioned. For less than $300 I have a system that is safe, and cannot backfeed the utility.
As a former lineman, I cringe when I see how many people backfeed their panels through a dryer outlet, or some other makeshift setup.:shocked:
Bill
