Oil & Fuel diesel fumes/yuk
   / diesel fumes/yuk #11
My wife doesn't like the smell and all but a little sniff me to. There is no play time until clean up, not even hugs. I have a high stack on mine.
   / diesel fumes/yuk #12
HomeBrew2 said:
I dunno, I really like Milkman's BX exhaust stack :D
Hey neighbor,
Question for you...how do you post those url's and name them...which one do you choose to do it. I use the "insert Link" but there is no secondary screen to name the url (for me anyway) that comes up like on the old system?
Thanks,
   / diesel fumes/yuk #13
Geez, at my house the smell of burnt diesel is an approdisiac. Admittedy, the Bride (an old farm girl from a previous marriage with a trucker Daddy) is probably a touch off typical on this matter.
Guess I should go give here a hug!
   / diesel fumes/yuk #14
3RRL said:
Hey neighbor,
Thanks,
Hey neighbor, I assume you're talking about the link in my signiture: It copied over from the old system. I have no idea how to do it from scratch now. Sorry. ... I am hoping to link to something within a post sometime that is so long that MikePA will be forced to instruct me how to do a short version. If it requires coding any HTML crap, it'll never happen!
Cheers!
   / diesel fumes/yuk #15
bikemiser said:
Am I the only one that about gags when you get to enjoy diesel fumes in your face for a few hours. I didn't mind so much at first but I must be getting more sensitive to it. Maybe I need a tall stack. That will look a little silly on a BX.
Actually.. I find the smell of burnt diesel a bit of a turn on. Now gas fumes? that's 100% different.. yuk!
I'm surprised your op platform is in a place that yuo can smell the stack?
I can't even get a hint of fumes from my diesels.. the stacks are tall and the flair points out away from me.
Can you install a flair pointing away from you? ( if you don't already have one? ).
How about positng a pic of tyour current setup.
Soundguy
   / diesel fumes/yuk #16
Guys the way to post URLs/links is as follows
HTML:
[url="http://www.tractorbynet.com"]TBN[/url]
This would end up looking like the following:
TBN
   / diesel fumes/yuk #17
BTW this forum uses what's called vB Code (a psuedo html type markup).
You can read over the available tags here vB Code
Ooh I just realized a few more features I hadn't before LOL.
If you go to your user control panel (The User CP link at the upper left), then go to Edit Options you can set all kinds of options, like having the threads sorted latest first, enter your time zone, and also select an ehanced interface for your posts editor which gives you all the quick easy to use buttons for most of these features.
   / diesel fumes/yuk #18
BP...
Thanks for the information. I presume you have to type the NAME in yourself as in your TBN example? I did not know that.
Thanks,
   / diesel fumes/yuk #19
When I was a kid I remember gas having a richer fuller smell and have wondered if the modern formulations lost some of that dare I say, sensuality. Also have seen some of the gas-cracker theorists for increased milage (was that english?) claim this is why they don't get the results they think they should.
Dennis
   / diesel fumes/yuk #20
Have you tried Power Service or some other brand Diesel Fuel Additive? I read somewhere that DFA (unspecified brand) tested very effective in reducing visible smog due to to more complete combustion. This might help in your case.
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
Kubota MX5400 (A57148)
John Deere 5115M (A57148)
John Deere 5115M...
