Diesel fueling made easy (easier, anyway)
   / Diesel fueling made easy (easier, anyway) #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I don't buy a lot of fuel, but I learned years ago that I hate to
lift fuel cans and pour then into the filler on my tractors. I have
seen several threads about this and how tractor users preferred
to do it.
My current solution is not ideal, but it is a great improvement. This does
not apply to you guys who buy LOTS of diesel, of course.
What I did was take a Jerry can and make a cap with a welded-on
tube so I could use air pressure to fuel my tractor. The cap also has
a schrader valve stem with the core removed. Finally I bought a used
fuel nozzle at the flea market, and I removed its anti-overfill valve.
I can now stick the nozzle in the tractor, lock it ON, apply air pressure
with my air hose, and put almost 5 gallons in the tractor in about 10
seconds. No more lifting and spilling.
I can easily lift and carry a full can to/from my truck whenever I need to
get more.
   / Diesel fueling made easy (easier, anyway) #2
Interesting idea.
I really miss the old plastic jugs with the flexible rubber hose. I could rest the jug on the FEL arms and tuck the rubber tube into the filler. Now with those rigid plastic supposedly environmentally friendly things I need to support all that weight and it's very difficult to avoid spillage. The rigid spout on my gas can is so fat it barely fits into my chainsaw so again there is generally much spillage involved.
Pete
   / Diesel fueling made easy (easier, anyway) #3
Interesting idea:)
I use the 5gal plastic Blitz jugs and just lay it on the hood with the bent fill tube in the tank and let the hood do all the work, works for me.
   / Diesel fueling made easy (easier, anyway) #4
im fairly shure your heater hose isnt going to stand up to the desiel fuel for long..... But nice idea!
   / Diesel fueling made easy (easier, anyway) #5
HELLO TO ALL,
you put the fuel into the tractor without a filter?
i use a funnel that has a fine strainer, and was
shocked at the debris that collects in there.
accordionman
wlbrown
   / Diesel fueling made easy (easier, anyway) #6
dfkrug,
Were you a race driver in a previous life????????????????
I have visions of a tractor making a pit stop, and 15 seconds later, being back on the "track".
Neat idea though. I sure wouldn't do that with gasoline, but diesel should be fine.
ron
   / Diesel fueling made easy (easier, anyway) #7
Air??? Air compressor, or extra air tank? How do you get the pressurized air? It works for you and that's all that needs to happen. I'm just curios is all about the amount of equipment needed to get the pressurized air. bjr
   / Diesel fueling made easy (easier, anyway) #8
accordionman said:
HELLO TO ALL,
accordionman
wlbrown
Afternoon wlbrown,
On my MF 1040 theres a fine mesh filter inserted into the top of the fuel tank, that does collect some small debris after time. The only problem with it is that you have to fuel slowly or it will run over ! :( The tractor also has the site bowl and an inline spin on filter. I generally get two 55 gallon drums filled and then transfer to a 2 1/2 gal can to fill the tank. Very seldom do I burn more than 2 or 3 gallons at one time.
BTW I just have a simple crank pump for transfer.
   / Diesel fueling made easy (easier, anyway) #10
As the link states in some of the responses! Pressuring up a non pressure rated vessel with air could be a disaster in waiting. :( :(
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
JOY G185XS PORTABLE AIR COMPRESSOR (A51248)
JOY G185XS...
2021 JOHN DEERE 8R340 LOT NUMBER 136 (A53084)
2021 JOHN DEERE...
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
