Diesel Fuel problems aboard our sailboat in Central America
   / Diesel Fuel problems aboard our sailboat in Central America #1
luepetri
Comox bc canada
Yanmar Mdel # 4JH4AE
Have never had problems with diesel before. We are experienced sailors and my husband very mechanical.
New Yanmar 4JH4AR 2 years ago. Left the boat in El Salvador and only ran it to make water periodically over the last nine months. Travelled to Costa Rica and have had nothing but problems since. Have emptied tank, cleaned fuel and continue to pump fuel through the tank to filter the gunk in it. From our research we realize that it might be bad fuel and or temperature problems............any other ideas?
   / Diesel Fuel problems aboard our sailboat in Central America #3
Dump that fuel, clean tank, new filters, then fresh fuel. Check for water leaks and treat all fuel that sits any period of time.
Chris
   / Diesel Fuel problems aboard our sailboat in Central America #5
If you have a lot of microbial growth in the tank, you'll likely need a strong biocide designed for diesel fuel to kill it.
The one I've used was a Case branded one, bought at an Ag dealer in Ont. Canada. Down your way, if you can't find anything at a marina area, try looking up a Cat(erpillar) dealer - they are often pretty good at covering out of the way places.
As stated, try and evaluate if there is a lot of water contamination in the tank, as that can accelerate this type of problem.
Good luck, Rgds, D.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2012 Club Car Electric Cart (A53424)
2012 Club Car...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
