Diesel Fuel problems aboard our sailboat in Central America
   / Diesel Fuel problems aboard our sailboat in Central America #1
luepetri
Comox bc canada
Yanmar Mdel # 4JH4AE
Have never had problems with diesel before. We are experienced sailors and my husband very mechanical.
New Yanmar 4JH4AR 2 years ago. Left the boat in El Salvador and only ran it to make water periodically over the last nine months. Travelled to Costa Rica and have had nothing but problems since. Have emptied tank, cleaned fuel and continue to pump fuel through the tank to filter the gunk in it. From our research we realize that it might be bad fuel and or temperature problems............any other ideas?
   / Diesel Fuel problems aboard our sailboat in Central America #3
Dump that fuel, clean tank, new filters, then fresh fuel. Check for water leaks and treat all fuel that sits any period of time.
Chris
   / Diesel Fuel problems aboard our sailboat in Central America #5
If you have a lot of microbial growth in the tank, you'll likely need a strong biocide designed for diesel fuel to kill it.
The one I've used was a Case branded one, bought at an Ag dealer in Ont. Canada. Down your way, if you can't find anything at a marina area, try looking up a Cat(erpillar) dealer - they are often pretty good at covering out of the way places.
As stated, try and evaluate if there is a lot of water contamination in the tank, as that can accelerate this type of problem.
Good luck, Rgds, D.
2011 International WorkStar 7300 Acid Tanker Truck (A52377)
2011 International...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2007 Fontaine DFT-5-8048WSAWK 48ft 35 Ton Drop Deck Equipment Trailer (A52377)
2007 Fontaine...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
