Oil & Fuel Diesel fuel line
   / Diesel fuel line #1
lragan
Ozark Mtns. Ar.
Yanmar F20D
Excuse the ignorance, but there are two "air relief" (?) devices between my fuel filter and motor. Are they air relief or primer type of devices to pump or prime fuel from the filter to the motor? The bottom one has a dripping leak and has, what I believe is, a hex type of nut that seems to be loose. Should I just tighten that down and see if the leak continues? Obviously diesel motors are not my strong suit and I firmly believe there is a lot of "smoke and mirrors" involved with them.
   / Diesel fuel line #2
Those are manual bleeds. They should not leak under normal operations. Tighten them up a little. The only time I "open" them is when I either drain out my fuel bowl or change out my fuel filter. It does not take much air in your fuel system to keep it from starting. I learned this the hard way.
   / Diesel fuel line
That's what I thought. My neighbor said they were actually a "priming" type of device that "pumped" fuel out of the filter. As I understand, when I change the fuel filter I should fill the filter bowl with diesel prior to re-installing the filter to prevent air from entering the system, then press the relief valve to allow any air to be expelled from the fuel line.
Thanks
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2020 JOHN DEERE 8370R LOT NUMBER 265 (A53084)
2020 JOHN DEERE...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
