Diesel Fuel Line Quick Connects
   / Diesel Fuel Line Quick Connects #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
This is something I have never seen discussed.
I mess around with generators and such. It's a hassle to rig up jerry cans for temporary testing.
What can one use for fuel disconnects? Diesel needs a return line too. Most cheap ones I see on E-Bay, I believe don't close when disconnected. And they usually are available only with a hose barb, not NPT fittings. Would changing temperature cause an issue with a closing type fitting, like in hydraulics?
I have a hundred or so old M style air fittings that I replaced. I was going to donate them, but can they be used for fuel? Will they leak, or suck air? Some are Milton, others are just Generic Chinese Junk. Will the seals deteriorate?
It would be nice to have a Yellow Jerry can with quick connects. It would be nicer if someone made a boat style Diesel tank with two lines. Although, I probably would not want to fork out the dough.
Thanks.
   / Diesel Fuel Line Quick Connects #2
I've used quick connects that shut off when disconnected for motorcycle gas tanks. They're really handy when you remove the tank. The ones I used never leaked. The small amount of pressure build up in a gas tank was never a problem when reconnecting.
I'd worry that the seals in the air connects would deteriorate in long term contact with fuel. Marine supply places sell fuel quick connects that shut off.
Thanks. Marine sounds EXPENSIVE!
   / Diesel Fuel Line Quick Connects #5
look on ebay outboard tank fittings
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
Utility Trailer (A52377)
Utility Trailer...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
