Oil & Fuel Diesel fuel in crankcase.....still!
   / Diesel fuel in crankcase.....still! #1
B7200HST
Hello,
B7200HST was getting fuel in the oil and the delivery pump diaphram seemed to be a likely cause. I replaced the complete pump with a new one and it didn't help. It runs like it did 17 years ago, so I don't suspect the injectors.
Do I have to buy a new injection pump ($5-600) because a 10 cent oring or 80 cent seal is bad?
Changing the oil real often is getting expensive too.
Thanks in advance,
David
   / Diesel fuel in crankcase.....still! #2
Are you sure that it is diesel and not hydraulic fluid? The seal on the hyd pump can go out and can fill the crank case with hyd fluid. I just wanted to give you something else to think about.
J.D.
Thanks JD,
It was low on hydraulic oil.
Removing the hydraulic pump was no fun.
I replaced the seal. The seal I removed and the shaft looked ok.
I ran it for 10 hrs and the dip stick has oil 3" up (way over full) again. It's also low on hydraulic oil again. What's causing this and how do I stop it?
Thanks in advance.
David
   / Diesel fuel in crankcase.....still! #4
Sometimes just replacing the seal on the Hyd pump wont always solve the problem. The problem may be in the hyd pump itself. When worn they wiil push the fluid past the seal no matter what. Many times it's obvious when you remove the pump and look at the seal, the lip will be blown out, other times it's less noticeable and the pump requires disassembly to get more clues.
   / Diesel fuel in crankcase.....still! #5
Welcome back Kubmech. Long time no hear.
Egon
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
JOHN DEERE HX14 LOT NUMBER 266 (A53084)
JOHN DEERE HX14...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
