Diesel Fuel and Stabilizer
   / Diesel Fuel and Stabilizer #1
scsims
Central, KY
Mahindra 5525
I am new to diesel engines and I started using Power Service in my new tractor. Do I still need to use a stabilizer in the fuel like I do for my gasoline engines that the fuel doesn't get used frequently enough?
   / Diesel Fuel and Stabilizer #2
Diesel does not go stale nearly as fast as gasoline (especially gas with ethanol) so an additive for letting the diesel sit for a while is not that important but using an additive to make up for the lesser lubricity of ULSD is important.
Do a search, you'll see plenty of talk about it. Just don't let Reg know your using an additive, he might tell you to purchase an extra carbon footprint offset...
http://www.tractorbynet.com/forums/oil-fuel-lubricants/149025-add-power-service-not.html
I run Power Service in all my diesel engines all year round. To each his own...
   / Diesel Fuel and Stabilizer #3
Use Marvel Mystery Oil in gas and diesel, then I don't have to worry about having a bunch of different bottles of stuff lying around.
   / Diesel Fuel and Stabilizer #4
Technically you should not use the standard Mystery Oil in Ultra Low Sulfur Diesel which is why they make a Diesel Fuel supplement.
That is why they say this about the standard stuff: Note for Diesel Fuel Users - This diesel fuel additive does not comply with federal low sulfur content requirements for use in model 2007 and newer diesel motor vehicles.
So you still have two different additives to keep track of and a whole two bottles of stuff lying around.
   / Diesel Fuel and Stabilizer #5
Dmace set you straight. Run the Power Service and you'll be good to go.
   / Diesel Fuel and Stabilizer #6
Do a search for the spicer lubricity diesel fuel report.Good read,coobie.
   / Diesel Fuel and Stabilizer #7
Thanks for the heads up, I've been using it for years now never had a problem. Why/what is the "federal requirements" about? Is using the regular MMO going to cause harm or is the company/higher powers just trying to make more money off of petroleum products? Just curious as to what the major differences may or may not be??????
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2005 Jeep Wrangler 4X4 SUV (A53424)
2005 Jeep Wrangler...
