Diesel engine started after 56 years underwater.
   / Diesel engine started after 56 years underwater. #1
bcp
Super Star Member
SW WA
Kubota BX2360
?????? ????? (pulling tank) T-34.
The latest news about T-34.
Have successfully started the diesel engine not replacing any spare part.
Have replaced only bearings on skating rolls.
Assembly of the tank will soon come to the end and it will be ready to trial runs.
It is planned in the following season to carry on tourists and to show it as a working exhibit of our museum.
The detailed information about T-34.
Germans have driven this tank in lake when fuel was terminated at deviation in 1944. It laid on depth of 12 meters. Above it there were 6 meters of peat and silt. During two weeks divers of club washed away silt above the tank. Any traces of solar oil or oil on water was not. Has found the tank Igor Sedunov on memoirs of local residents. A technical condition of the tank ideal. Fuel in tanks was not, and oil did not leave the engine.
The men found the T-34 in amazingly good condition, with no rust, and all systems except the engine in working condition. The layer of peat and the high acidity of the marshy lake had created a kind of protective cocoon around the tank, sealing it off from corrosion and preserving it through 56 years under water. To the team's delight, nearly every part and mechanism proved to be in perfect working order after cleaning. The fuel tanks were found to be empty, confirming the assumption that the tank had been abandoned and dumped in the lake due to shortage of fuel. The diesel engine had leaked no oil. Astoundingly, without replacing any spare part, the team managed to start up the Diesel engine.
Another article with more photos
Update On Recovered T-34 Tank With German Markings
Bruce
   / Diesel engine started after 56 years underwater. #2
That is incredible.
   / Diesel engine started after 56 years underwater. #3
Amazing it didn't leak any oil out of the crankcase in all of those years. I guess Russian seals are pretty good.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2006 MACK MR CAB & CHASSIS (A57880)
2006 MACK MR CAB &...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2014 Ford F250 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F250 4x4...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
2013 INTERNATIONAL REEFER TRUCK (A57880)
2013 INTERNATIONAL...
