diesel disaster
   / diesel disaster #1
ford4610
ford4610
Help.Gas was dumped into my ford 4610.The tank was drained as well as the sludge bowl and filter.The injector pump was also drained and now this is my problem.I'm a new tractor guy so I'm learning as I go. please help:( how do I prime the injector?
   / diesel disaster #2
Hello ford4610, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
   / diesel disaster #3
Did you run it on gas? Gas in a diesel engine is not an uncommon error. Normally it does not cause long term harm.
Is your current problem that you need to prime the fuel pump?
   / diesel disaster #5
I did the same thing, Drain & change every filter. Blead out injector lines. It will be fine.:)Most will not run on gas. the gas wont pass through the injectors.
Army Grunt
   / diesel disaster
Yes Sir, you are correct that is my problem, if I could fix it that would be fantastic. If you are able to help me out I would be able to sleep. Thanks for replying to my situation. Ray
   / diesel disaster
Army Grunt
thanks for your reply Army grunt,I have change filter and injector ,the problem now is I dont know how to prime the injector to gget fuel to the engine. thanks Ray
   / diesel disaster #9
there should be a push pump and a bleeder screw on the filter housing .Open the bleeder screw and push pump plunger until all the air bubbles come out. then screw the bleeder screw back in .You should be in bussiness
   / diesel disaster
You who hunts the bear, Thankyou, Yes I understand , and thank you very much. I will start at the beginning and fix my disaster. I will be back in touch to let you know the outcome. Hunt well and shoot straight.
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2016 Chevrolet Tahoe (A52377)
2016 Chevrolet...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
