Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #11
Loosen the cap and see if it will run better. It could be the strainer holds the cap up a bit to allow the tank to vent.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #12
Loosen the cap and see if it will run better. Could be the strainer holds the cap up a bit to allow the tank to vent.
I have tried and tried to get that screen out of the tank. Had it twice, but couldn't get a grip on it.
Now I can't see it at all!!!
:mad::mad:
:confused:
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #14
Take a look at getting something like Wireless Endoscope / Borescope Inspection Camera from Amazon. You can find them for around $25 and they work with a smart phone / tablet / laptop. They usually have various pickup tools with them for retrieving things from small dark places.
Most are waterproof but i'd be careful about putting one down a full tank of fuel.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #15
Again from what I understand , its from the can not the tractor.
After you moved it did the situation get better as far as running wise. I am guessing you could save some time and just leave it there. Drain the fuel that is probably where your issue is.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #16
I was going to recommend the cheap borescope too. Mine was like $12 or $15, attaches to a computer and has a light built in. If you get it in the diesel that might cause it to die sooner rather than later but even if it only works for this one task it'll be worth it.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #17
Here's what I do with those new 5 gallon cans that won't pour: I put a one gallon plastic juice jug on the ground and pour it full from the can, then pour that in the tractor using a filter funnel. It's much easier to pour from a one gallon open container than from a 5 gallon jug with one of those new no pour no vent spouts, especially when trying to hold the full 5 gallon jug on top of the tractor hood for the three or four minutes it takes to pour.
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #18
This sounds kind of familiar. I've fished in my fuel tank too. And with about the same results. Ended up removing it and holding it upside down. But maybe that isn't necessary here.
Lets back up a step or two. I kind of doubt that the cap or screen or whatever that fell into the fuel tank is what is making the tractor run poorly. My guess is that whatever was being screened out of the fuel got dropped into the tank and passed from there down into the fuel filter where it has plugged that filter up. That's common enough, and a plugged fuel filter exactly fits what you said about what is happening as it runs. The fuel filter is plugged up and the motor is starving for fuel.
So I'm afraid that even if you do get the elusive screen out of the fuel tank you won't accomplish anything except satisfaction - you are still going to need to clean out the fuel filter. So I'd leave the tank alone for now and concentrate on the fuel filter. I'll also bet that cap & screen can flop around in the tank for a long time without damage to anything.
Every tractor has a fuel filter - often the filter lives in a clear plastic housing so you can see dirt and water. To find the filter, follow the rubber hose coming out the bottom of the fuel tank, and that leads right to the fuel filter. There is often a little handle on the fuel filter housing that can be used for turning the fuel flow on & off when you stop the tractor, or to stop the flow of fuel out of the tank while you work on the filter.
And there is a little finger-push valve on top of the housing for burping the air out of the housing after it has been cleaned out & reassembled. This is easy stuff to do even if it is a bit bit messy it is less so than mucking around in the fuel tank. You'll want a plastic container, a brush for cleaning the filter and housing, and a few pairs of pliers plus maybe some waterpump pliers,..... & a screwdriver or two. That ought to do it. The filter housing us almost always deliberately made to be simple, accessible, and easy to deal with by owners with simple hand tools. It's made that way because all over the world, dirty contaminated diesel fuel is common, and cleaning out the fuel filter is a common job.
Enjoy!
rScotty
   / Diesel Cap Filter Fell into Tank. Tractor decelarates, loses momentum. #19
It was a Shell pump at an EZ-Mart. Funny thing was, I tried to use one side of the pump and it would not engage I switched sides and it engaged immediately. Crazy Tractor Lady
Are you absolutely sure it was diesel fuel that you put into your tractor?
UPDATE ON THIS TRACTOR.
I am starting a new thread on this issue. It is still losing RPM.
The new thread will be Losing RPM
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2243 (A58376)
2243 (A58376)
2026 Hillcrest 14166SPT 22ft. 7 Ton T/A Tilt Deck Trailer (A56858)
2026 Hillcrest...
Sellick S60 Forklift (A57148)
Sellick S60...
New/Unused Electric Golf Cart (A57453)
New/Unused...
