Did you get all the tire loading you paid for
   / Did you get all the tire loading you paid for #11
Another thread we just posted to, a new poster asked how much for a certain sized tire. I looked it up in the Rimguard chart and it said 29 gallons for 3/4 fill. Another poster posted the Firestone chart and it said 34 gallons for the same sized tire for 3/4 fill. A delta of 5 gallons. Makes you wonder whose chart they followed.
Actually I do not know how much I was charged as it was included w/o a line item in the purchase price of the tractor. My main concern is the weight I am giving up. If indeed each tire can be filled with another 4 gallons that's 8x10.7= 85lbs. Really do not know if that is significant traction wise but it seems it could be.
   / Did you get all the tire loading you paid for #13
85 pounds won't make any difference
   / Did you get all the tire loading you paid for #14
Sure you can. Just get a tire pressure gauge designed to work with liquid.
Northern Equipment has them, and I'm sure you can find one at a good hardware store or farm equipment supplier. The main difference is they have a low pressure range, suitable for tractor tires, and a spring to force the liquid out of the gauge when you remove it from the fitting. You have to read it while it's on the fitting, or hold the stem when you remove it so it doesn't slip back in.
Terry
Oh okay, thanks for the info. I didn't realize they made guages to work with liquids, I'll check out my hardware store.
   / Did you get all the tire loading you paid for #15
I wouldn't worry about it unless they were filled with something corrosive like calcium chloride. If the rim isn't completely covered, it will begin to rust and then bigger problems.
   / Did you get all the tire loading you paid for #16
I once thought we were shorted some oil in a 55gal drum at work by the level of the condensation after coming off a cold truck. Opened the drum to find that the drum was full. The first few inches of the oil were above the dew point. As the oil warms, it rises to the top, so no condensation. You may have the same thing going on in your tires.
Interesting Dan. Not certain how I would apply this to beet juice but interesting none the less.
   / Did you get all the tire loading you paid for #18
Thump it with your finger like you would a watermelon to test for ripeness.. the density change will be audible if you switch back and forth between the air and the suspected fluid interface.
Or, You could get your drill out and drill a hole just above the suspected interface and see what comes out. air or liquid.. Just kidding...:)
   / Did you get all the tire loading you paid for #19
Scan with an IR thermometer to find the interface
   / Did you get all the tire loading you paid for #20
Why couldn't you just park your tractor with the valve stem at the top to check the air pressure? They don't fill them all the way up.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
Pallet of (4) 10 Lug Misc Wheels (A48837)
Pallet of (4) 10...
UNUSED CFG SKID STEER PALLET FORKS (A50460)
UNUSED CFG SKID...
2017 JLG G5-18A Telehandler (A50490)
2017 JLG G5-18A...
(1) 12ft Livestock Panel (A48837)
(1) 12ft Livestock...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A50397)
2019 Ford F550 4x4...
