Did something really stupid - wont start now
   / Did something really stupid - wont start now #1
Wanderer
Tractor: TC33Da
So, I was looking at the throttle linkage for a problem with the tractor not going to idle. I disconnected the 4 pin connector from the key switch and noticed some corrosion which may have been causing the blowing starter fuse issue. I cleaned the key side with a wire brush then did the same to the harness-side, forgetting to disconnect the battery. Well, tiny little sparks at the power-relay block and now it won't start or turn. Brilliant.
So my question is - did I just blow the relays or something else major? No fuses are bad.
   / Did something really stupid - wont start now #2
I don't know your machine, I'd get my hands on the schematics. Start tracing with a volt meter and continuity meter and see where it went wrong.
In theory a fuse or the like should've gone.
This could easily happen to anyone.
Joel
   / Did something really stupid - wont start now #3
I'm in agreement with Joel. I think you need to check your fuses with a voltmeter set to ohms. I'd bet you will find a blown fuse. If you don't find a blown fuse in the fuse block, look at the main fuse (30 amp?) down near the starter.
Thanks for the replies everyone. It looks like it fixed itself. I took all the fuses and relays out and put them back it. Perhaps it the panic of it all I did not have the brake on or something when I tried to start it after this happened. Just glad it was not more painful.
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2013 Nissan Juke SUV (A51694)
2013 Nissan Juke...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
