Did Satoh offer a front suitcase weight option?
   / Did Satoh offer a front suitcase weight option? #1
Volvoman
Bronze Member
Looking for some suitcase weights that will actually fit onto the front bracket of my S-373 Beaver III. Did Satoh offer such an option, or will I need to go on a scavenger hunt? Vvm.
   / Did Satoh offer a front suitcase weight option? #2
Not shure, but they probably did offer them but since there are no longer any dealers for Sotah (Mitsubishi) a scavanger hunt will be necessary.
Do some searches as many TBN members have made some very creative weights.
If you were to locate some, shipping would really hurt.
   / Did Satoh offer a front suitcase weight option? #3
Those suitcase weights are not cheap I have 4 on the front of my 372. But I have seen them on Craigslist already so they are around just have to locate them.
By any chance, could you post a photo of your weights? Maybe they are the same as used on some other tractors......?
vvm
   / Did Satoh offer a front suitcase weight option? #6
Go to a scrap metal recycling center. I go to cherry city metals in salem oregon. They usually keep around the usable cool stuff to sell at a higher than scrap but still low price. Otherwise spring steel seems heavier than mild steel. You could get some used leafs (random would be cheapest) and cut them to length, weld them and bolt them to the front.
   / Did Satoh offer a front suitcase weight option? #7
I have a round wheel weight bolted on the front of the Buck with a homemade front hitch too.
Thanks for everyone's replies. Good fortune came and brought 3 Ford cast iron weights from a 1600 subcompact tractor. Each weighs 32#, so total of 96#. They look like they could have been original equipment, as they fit nicely onto the 9.5" wide front bracket. Each weight is 3" wide. The three weights are enough to counter a 42" tandem disc, 5' landscape rake, 4' rear blade, and single row JD 71 planter unit I have for the tractor. I don't want to overload the front end too much , as I don't know how much it can take before the excess weight starts to do some damage to front axle components when there isn't a rear mounted implement to counter the front weight. vvm
   / Did Satoh offer a front suitcase weight option? #10
My beaver has 3 solid bars of steel mounted to a bracket. It appears to be some sort of after market setup as it has pinch bolts to secure it. Works great to keep the front on the ground and to be able to steer.
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
