Did Kioti...
   / Did Kioti... #11
Thaks for the reply..... is Midwest the same as First Choice? Do you stock all colors?? thanks again....
   / Did Kioti... #12
The last of the First Choice implements that were made by Midwest are approaching 2 years of sitting on a dealers lot. Midwest is "the real thing" not something relabeled in a old Coke bottling plant. It's hard for me to understand new stuff this old on a dealers lot. Most of the good Midwest dealers have a turnover rate of 4-6 times a year. Currently orange is an exclusive color for Kioti dealers but you can have Kubota Gray. Most dealers will stock one or two colors.
   / Did Kioti... #13
Curved tines are a mixed blessing. The curve allows the tine to enter the turf in a straight path since the tine is "rolling" into turf. Coming out, the point of the tine is cut at an angle to reduce the turf damage as the tine "rolls" out. This creates a slot under the turf with a small amount of compaction, but a smaller entry wound. The worst style is the straight spike as not only does it create a larger entry/exit wound, but it also compacts the soil around the hole in the process. Works kind of like a sheep's foot roller on construction sites.
   / Did Kioti... #14
</font><font color="blue" class="small">( Curved tines are a mixed blessing. The curve allows the tine to enter the turf in a straight path since the tine is "rolling" into turf. Coming out, the point of the tine is cut at an angle to reduce the turf damage as the tine "rolls" out. This creates a slot under the turf with a small amount of compaction,..)</font>
Can this small compaction be avoided completely? For example, by a small design change in the point of the tine? I have an idea - but you have experience.
   / Did Kioti... #15
The vertical coring units common to golf courses come the closest to absolutely 0 compaction from the action of coring. Normally, the small amount of compaction generated by the rolling units is more than offset by the removal of the core.
   / Did Kioti... #16
Re: Aerator
So, I understand from your words that there is really no need to worry about the small compaction generated by these curved hallow tines rolling in a straight path into the turf. Thanks. (ps: picture I attached may attract your interest)
   / Did Kioti... #17
Re: Aerator
Thanks for the picture. We knew this particular manufacturer was doing a little "homework". LOL
   / Did Kioti... #18
I called the local Kioti dealer to inquire about price and availability.... told me that they don't carry the Kioti aerator because it is too expensive and that the Agrafab one was just as good and more than half the price at $275.00.....
   / Did Kioti... #19
I don't see any three point aerators listed on the agrifab website /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Don
   / Did Kioti...
I got the First choice,kioti,midwest whatever model, 48''
cores nice and deep with the addition of a couple hundred pounds added, Im having some weight plates made for it.
It also appears that the 3pt hitch on my X-575 lifts more than
its rated for..for now anyway..
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
