Did I ruin my new coil by reversing the polarity?
   / Did I ruin my new coil by reversing the polarity? #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I bought a 1959 Minneapolis Moline 4 Star for restoration because I liked its looks and was in really good condition. The engine did have a slight miss so I bought plugs, points, capacitor, rotor, cap, and wires. I put in the plugs first and no change. I put in the new points, capacitor, rotor, and cap next, tested it and saw only slight improvement. I next changed all the wires and found the problem -- the tower of the coil was completely corroded and the whole socket inside pulled out with the wire. I installed a new coil with the wire from the ignition switch to the positive terminal and the grounding wire from the points to the negative terminal. The engine just sputtered and could not run for more than 5 seconds. After a lot of cranking, I put the battery on a charger. I was really surprised to find that the tractor had a positive ground. The 4 Star was made for about 7 years and apparently all were positive ground. But my problem is: after correcting the polarity of the coil the tractor still won't start. Could reversing the polarity have damaged the coil or capacitor?
   / Did I ruin my new coil by reversing the polarity? #2
Unless there is some kind of electronic replacement, polarity should not be an issue, in my opinion. The capacitor is likely polarized and thus polarity sensitive. It would probably not work to capacity (in mfds) but I don't think it would be damaged. Such caps just clamp on don't they? So that would be the negative terminal. You would have to find a reverse one. Or attach a wire to the case and heat shrink it or similarly insulate it.
Is the coil the right voltage? 6 or 12?
Thanks for the reply IT. The coil was 12v. I worked backwards putting back the original cap and rotor with no change. Put back the old coil and wire to cap with no change. Then put back the old points and capacitor and everything is fine. Point gap and everything was triple checked before going back to the old parts. The vendor for the parts has been contacted for refund or replacement.
   / Did I ruin my new coil by reversing the polarity? #4
AND, the Correct answer is . . . . . . ?
It seems that the capacitor was damaged by reversing the coil polarity.
   / Did I ruin my new coil by reversing the polarity? #6
I find that a little hard to believe, but so be it. It's not a semiconductor. Do they make caps with the (outside) can being positive?
   / Did I ruin my new coil by reversing the polarity? #7
Compare the cam on the old vs new points. Or possibly the mounting location is different on the base plate. Your timing may have just been completely out to lunch.
Point well taken, no pun intended.
   / Did I ruin my new coil by reversing the polarity? #9
I have bought brand new capacitors that were bad. Yours may have been bad new.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2015 Ram 3500 Crew Cab Truck (A52384)
2015 Ram 3500 Crew...
2020 INTERNATIONAL LT625 DAY CAB (A53426)
2020 INTERNATIONAL...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
