Did I marry the right woman or what?
   / Did I marry the right woman or what? #21
I think you're looking a bit small unless your just maintaining.
Hire out any heavy clearing to bigger equipment.
Yes, you are very lucky about your wife, I just wish she had some "green" in her bloodlines! :) :) :)
   / Did I marry the right woman or what? #22
If you notice, most of the guys replying go right past your question and start discussing tractor options. Goes to show that these guys care more about tractors than women. Bunch of sickos! :)
I too think you are on the right path with a 35Hp CUT. From what little I've seen, horses do far more damage than R1's :) .
   / Did I marry the right woman or what? #23
And now for a minority report: I now have 4x4 and R-4's (prefer them over R-1's.) I find that there is a degree of traction where R-1 tires are noticeably better than R-4. I find in practice that this is a narrow range. As traction is reduced to the point that the R-4's spin too easily, just a little additional loss of traction and the R-1's spin too.
The upside of the R-4 is less damage to surface in virtually all situation's (except the narrow window between loss of traction for R-4 and loss of traction for R-1.)
If surface damage is not an issue get the most aggressive tires you can find (steel tires with giant lugs have great traction.) If you often operate in the "window" described above then you will be hapier with R-1 than R-4.
Turfs are more for lawnmowers, even lawn mowers with a 3PH on the back and or a recognizable tractor mfg logo painted on.
Pat
   / Did I marry the right woman or what? #24
CavinMan said:
Asked her what she wanted for our second anniversery, and she replied "A tractor!" :D
Any thoughts?
Yeah, where do I find one of those?! :p
   / Did I marry the right woman or what? #25
It usually doesn't work that way. THEY FIND YOU!!!
Pat
   / Did I marry the right woman or what? #26
I too think you are on the right path with a 35Hp CUT. From what little I've seen, horses do far more damage than R1's :) .[/QUOTE]
If uneven footing from tire tread impressions is the main worry then SHANE and others are correct in that horse foot imprints produce equally uneven footing but no apparent problems for the animals. R1's seem the best and most useful choice for your requirements as explained by others in this tread.
   / Did I marry the right woman or what? #27
My wife was fine with me buying a tractor if I would show her how to run it!!
   / Did I marry the right woman or what? #28
I had to convince my hubby to buy me the first tractor. He only had to see how much work I was able to do with it to be sold for life. :D
You just described our new land. We opted (I placed the order Friday!) for a JD 4320 (48hp). I compared the smaller body size of the 3000 series side by side, and decided that unless I went all the way down to a 2000 series, manueverability wasn't going to be that big of a difference. I opted for the larger tractor, for more stability, better ground clearance, and future options in case we want to clear more of the land in the future.
I went with R4's.
   / Did I marry the right woman or what? #29
I guess i gotta give kudos to my wife as well. Beck when i was mowing with a 33hp tractor i needed a bigger one.. and was gonna get a 70hp ford 5000.. oldy but goody... she instead urged me to get a virtually new 90+ hp tractor that i mow with today.. my 7610s.. gald she did.. I love that tractor...
Soundguy
   / Did I marry the right woman or what? #30
Ithink you married the right one:) The only problem i can see is what will she want for your 5th anniversary?:D :eek:
   / Did I marry the right woman or what? #31
Cavinman:
Understand first that I am stuck in the 1950's when tractors had no plastic, no power brakes, (usually) no power steering, and always had a standard transmission with a clutch, and were expected to last at least 10 years in heavy farm service, and usually lasted 20 years.
I have now a 1995 Kubota, 2001 Kubota, and 2006 Kubota and they have gotten progressively more plastic and electronic. The 1995 Kubota has required a new fuel shut off solenoid and glow plug timer. The 2001 Kubota required a new fuel shut off solenoid, starter solenoid, and ignition switch. When I looked at the 2006 L4330 the next generation L4340's had just come out and I was completely turned off by the electronic engine and HST control system. Not only do I think they are unnecessary and even a hindrance to any reasonable operator, I can't imagine that the electronics will operate 10 years without failure. And 20 years from now parts are likely to be unavailable.
I know nothing about the other brand you are looking at except that they seem to get good reports on this bulletin board. But if they are cheaper, have no or fewer electronics, and you have a dealer close by, I would avoid the Kubota "40" series because they are simply too refined and complicated for long term use. The "old" series L4330 is too electronic for my tastes, but the local dealer is superb and that made the difference.
I am reminded of the early 1990's when Mercedes overengineered their cars with gadgets like "bumper markers" that raised up out of the rear fenders when you went into reverse so you could see where the bumpers were. Not only did that stuff break, it was expensive in the first place, and served no real purpose other than a sales tool.
OK. I will get off the soapbox. Enjoy whatever you get.
   / Did I marry the right woman or what? #32
Not to duck the first question, but if you are planning to use the tractor off of the 7-8 flat acres, I would go out and measure the slopes. (You can get a $5. angle meter from Habor Freight.)
If you have more than 10 degree slopes, I would encourage you strongly to consider a tractor made for slopes. (And before we get bogged down in a tractor color discussion, I've been out there with wheel weights, and calcium filled tires. For my $0.02, they are bandaid fixes to a sub-optimal slope design.)
If it is over 20 degrees and you want a front loader, it is a short list; Aebi, and Power-Trac. If you don't, consider a crawler.
Roll overs are a leading cause of death for farmers.
Live long, live happy.
So now we're tractor shopping.
We have 70 steep hilly acres, including maybe 5 to 8 acres of level pasture - the rest wooded. Plus wife's best friend has adjoining 100 acres, similar layout. Will be using the tractor to cut and maintain horse trails, a cross-country course, general property maintenance, road maintenance, that sort of thing. No hay baling
Right now, after visiting a couple of (relatively) local dealers, we seem to be trying to choose between either a Kubota 3240 or 3540, and a Kioti DK35se. All three in 4WD HST, and looking at a loader, box blade, rotary cutter and rear finish mower and a trailer to haul it.
The prices are pretty close, the Kioti is about $700/1800 cheaper than the two Kubotas, but the Kubotas have a considerably stronger loader, and I must confess I like the intelligent HSD on the Kubotas.
Any thoughts? Is 35hp going to be sufficient for the kind of propety maintenance I have in mind?
John Deere Z994R (A60462)
John Deere Z994R...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
