Dirt Moving Did I kill my tractor?
   / Did I kill my tractor? #1
frann
Effingham, sc
Massey Ferguson 1428v
I used a tiller to break up some very lumpy clay like soil before planting bahia. This supposed to be a horse pasture some day. Anyway now it seems my little 28 horse power Massey Ferguson does not have as much pick up and go as it used to have. I used to mow the pasture, another one with a finishing mower at around 25 rpm's. Now I seem to be at full power at 20 rpm's when I mow with the finishing mower. What happened and can it be fixed?
   / Did I kill my tractor? #2
Are you saying that you can't get engine to turn faster than 2000RPM? If so, I'd check fuel and air filters as they're easy and likely candidates.
It would not go faster than 20 rpm's with the pto going with the mower attached to it. Right after I finished tilling the pasture, I had all filters and fluids replaced on the tractor.
I just checked the paperwork. The oil, air and fuel filters were changed and the antifreeze was changed.
The oil was changed
   / Did I kill my tractor? #6
Is that engine RPM, or PTO RPM?
I can see 2000 PTO RPM max better than 2000 engine RPM.
Aaron Z
   / Did I kill my tractor? #7
Aaron Z
The rear PTO RPM is generally 540, so I imagine that is engine RPM.
   / Did I kill my tractor? #10
If you can't get engine power or rpm on a old fashion diesel the normal problem is fuel or air. You can have bad fuel, so check the fuel flow. Does it smoke different?
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2017 Ford F550 (A55973)
2017 Ford F550...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Hose Reel (A55787)
Hose Reel (A55787)
