Did I kill it? 2016 L4701 HST stopped moving while mowing. PTO Dead too
   / Did I kill it? 2016 L4701 HST stopped moving while mowing. PTO Dead too #41
Glad it got resolved and you got your tractor back!
   / Did I kill it? 2016 L4701 HST stopped moving while mowing. PTO Dead too #42
Got my tractor back. Repaired under warranty but only by about 2 months! It was something about a needle bearing inside the transmission moving out of place and allowing a pressure plate to move and not engage this no movement from HST. This is apparently something Kubota knows about happening because they have figured it out and had produced a shim kit of some sort to place inside the transmission to correct the problem. Thank goodness it was still under warranty!!
Good you got it back. And impressive that Kubota was on top of the cause and had already figured out a kit to fix it. This isn't the first time that we've seen "known issue" repairs done by Kubota, including some done right at or slightly past the end of warranty. That tells me that someone at Kubota is paying attention to how their tractors are performing out in the real world even if we don't here about it on TBN.
rScotty
What worries me is if I would have waited a few more months, the repair bill would have been $3200 for a "known issue." The dealer said "be glad you were still under warranty" and I asked so in September (warranty until Aug) would this have been "all at my expense" even though it is a known issue and he said yes. If there is a problem with Kubota L4701 HST transmissions large enough to make a fix kit for, and the repair is $3200 at less than 90 hours, owners should have been notified. Just my opinion.
   / Did I kill it? 2016 L4701 HST stopped moving while mowing. PTO Dead too #44
Agree. Even with vehicles it sucks that manufacturers have known issues but won’t usually cover them out of warranty. Granted I suppose some things might be depending on the manufacture, but I have seldom heard of this.
In your case I wonder if there are any symptoms other owners could look for prior to the failure which could be after their warranty ends.
Agree. Even with vehicles it sucks that manufacturers have known issues but won稚 usually cover them out of warranty. Granted I suppose some things might be depending on the manufacture, but I have seldom heard of this.
I don't think so. It went from running fine to not moving... dead in the middle of the field.
   / Did I kill it? 2016 L4701 HST stopped moving while mowing. PTO Dead too #46
Would the Kubota insurance have covered this after your warranty period?
2014 SKYTRAK 10054 TELEHANDLER (A58216)
2014 SKYTRAK 10054...
1627 (A58375)
1627 (A58375)
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2025 CFG Industrial H12R Mini Excavator (A56857)
2025 CFG...
New Holland WorkMaster 37 (A53317)
New Holland...
