Did I hurt the Pump/Trans?
   / Did I hurt the Pump/Trans? #1
Joelk
PA
Cub Cadet 3165(for Parts) 3100, 3206, 3240, 3200 with Snowblower, 5252 with FEL and 60" MMM
I have a 3165 Cub Cadet that has the shaft drive Hydrostatic Transmission.
It had a leak from the bottom of the rear axle housing and I removed the rear end cover to try to stop the leak. I put it back together with some silicone sealer and then drove it to my shed to park it. As I pulled it into the shed I noticed that the trans and power steering were acting up and I just got it pulled into the shed as it quit moving and lost power steering.
The rear was full of fluid and the only thing I could think of was that I must have sucked up a piece of silicone and it was blocking a passage somewhere in the system. I assumed I was going to need to tear the entire trans down.
I pulled the entire trans/rear out of it (took about 2.5 hours) and then pulled the rear axle cover off. No loose silicone, but I did find what was causing the problem. I apparently left a paper towel in the rear axle and it got sucked into the pump pickup. I felt like one of the Surgeons that left a sponge in a patient. The paper towel is intact so I don't think any if it went through the system, I think it was just starving the pump of oil.
I drove the tractor about 100 yards before it stopped moving and I probably left it running for another 30 to 60 seconds trying to figure out what was wrong.
DID I BURN ANYTHING UP IN THE PUMP/TRANS?
I don't want to tear the pump/trans apart if I don't need to, but by the same token, I don't want to spend 5 hours putting it back in and tearing it out again, if it is definately damaged.
Any way to test the pump without putting it back in the tractor?
   / Did I hurt the Pump/Trans? #2
There was oil in there, so I would expect it to be fine.
   / Did I hurt the Pump/Trans? #3
Welcome to TBN.
Would there be in line screen/screens in hyd. lines which maybe plug?
   / Did I hurt the Pump/Trans? #4
I just finished rebuilding my hydro-pump last weekend. Sounds like it just ran out of fluid to pump and stopped. All the parts inside were not hot and were coated with hydro fluid so I would say everything should be ok.
Dont feel bad about the paper towel, I thought I had left 2 rubber bands in my rebuilt hydro unit ,wasnt entirely sure, slept on it, then decided to resplit the tractor and unbolt the hydro. Sure enough, I had left those binders in there. Cost me a day, but saved me countless potential future problems.
Thanks for the replies.
I called the local CC Dealer and talked to Mechanic today. He said that no longer than I ran it, he thought it would probably be OK.
After work I started putting it back together and just finished getting it back together enough to start it up. No test drive (no fenders/seat or gas tank) but I started it long enough to confirm that I got power steering and forward/reverse so I think it is probably OK and I will finish reassembly tomorrow.
Morris9460, if it's not OK, how hard is it to rebuild the pump and about how much did parts cost?
   / Did I hurt the Pump/Trans? #6
The hydro-pump are really simple machines, not much to them. My tractor is a Kubota , but the hydro and gear case is made by Daikin of Japan. If I had bought all the parts that I replaced from my Kubota dealer costs would have been over $1000. I researched Daikin, found a company called Sauer Danfoss who distributes Daikin products in the US, and a company called Hydro Gear that supports parts for Daikin hydros. These hydros are used in many big name tractor companies like John Deere , Kubota, many others. Anyway, fortunately I have a Hydro Gear parts dealer close to me, so I could order parts direct, they also have many in stock, just not the ones I needed. Anyway, cost in parts was about $200 from hydro gear and $100 from Kubota, then I had the back plate resurfaced for $70, at a machine shop. Oh yea, also needed a new gasket, Hydro Gear charged $14 for the gasket and seal kit, but it wasnt exactly the one for my hydro unit, so I had to go to the Kubota Dealer for it,$42 for just the gasket.:mad:
2017 Chevrolet (A55973)
2017 Chevrolet...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2012 John Deere 624K (A55272)
2012 John Deere...
SPRAY TRAILER (A58214)
