Did I buy the wrong generator?
   / Did I buy the wrong generator? #111
Next time we need something "excited" I'll ask her if she minds if I take a picture of her giving the generator a "come-hither" look. Good chance I'll be un-employed or injured shortly afterwards, so I may wait until I'm closer to retirement.
Sean
Maybe you can get her to do a "Training" video for all us TBNers that may need to flash their gennys?
   / Did I buy the wrong generator? #112
MadJack said:
We live off grid...
That you live off grid is impressive. Are you well past any power or just simply choose to be independent? I am also impressed that you can operate all that you do on a 3000 watt generator. And lastly, I concur with your comments on quality of generator. That is a significant risk of the low cost generator unless you use it at the construction site.
   / Did I buy the wrong generator? #113
JD4520, I'm not the "green" type, I live this way for independence and economics. Central Maine Power has given me a quote of $18,000 to run wire down 5 poles on the main road [state highway] and 3 poles up my driveway that the phone company installed before I started building. That is wire and a transformer plus labor.
With what I can do here on much less than $18K I can live comfortable, plus I never have to deal with outages and the new RF-Meters screwing up my electronics and/or my health.
I have started another thread, 'off-grid living' so's I don't thread-jack this one. Sorry if I offended the original poster.
MadJack,
You can hijack my any of my threads, anytime. :thumbsup:
I'm loving your new thread too (more pictures please!). Especially want to see the pooltable room. My pool table is still in my "Bar" in the basement of my big city house that is now rented out to a wonderful retired couple... But I miss my monthly gatherings of all my freinds around the pool table... I may never hove room for one in this house...
See! I hijack my own theads!
Merry Christmas,
Be well,
David
   / Did I buy the wrong generator? #115
How long does it take for a full carb to completely evaporate?
Late to the game, I wanted to make a few comments about all I have read
Your question is a good one, and I don't know. But I wanted to mention that the problem can happen with a full carburetor.
I have done carb work for years on a variety of carbs..and the WORST are old motorcycles and old tractors that have the fuel gravity flow from the tank. As some of the fuel evaporates, it is replenished, and this continues until no more fuel is left. (Although frequently in this process, the float eventually sticks either open or closed.)
So, we are not talking about the solids of a bowl, or a partial bowl, but a partial or entire tank in many cases. It is a horrible carb job to do.
Idle jets are tiny. Many carbs have filter screens so tiny in mesh, that a particle cannot get through which would clog the jet. Yet..I see clogged jets frequently, so there can be no doubt how this happens. It is coming through in a liquid state, and then solids are being formed in the bowl. And it need not be an evaporation issue, but can also be an oxidation issue where oxygen attaches making new compounds. Products like Stabil are mostly anti-oxidants.
Shellac was mentioned, and is a product of the Lac bug, and is an excellent insulator. Most folks call what in in the bowls of carbs "varnish" in these parts, but I also hear gum sometimes. (Not trying to be a stickler...just looking for a way to tell folks about handy bug secretions.)
Shellac - Wikipedia, the free encyclopedia
And it really is the "She" lac. Apparently the "he" lac only helps us by propagating more "shes":) (Incidentally, that's one of the best things many of you ever did for the world too. :D)
two cycles...frequently these are protected by: the lube oil additive is also a fuel stabilizer. Also, very little of the fuel is exposed to open air, and fuel does not gravity flow into the carb. The 2-cycle carb has its own built-in fuel pump driven by crankcase pressure oscillations. So 2 cycle fuel has stabilizers by default, and the fuel pump is in the carb, so small evaporation will not be replenished by gravity flow.
When I purchase a device with a 2 cycle, I insist on those with the little push bulb (primer bulb.) The bulb is not a primer of the engine, but instead a primer of the fuel pump. If you dump all the fuel out, and then use the primer, you frequently can replace that fuel with air (perhaps not on all motors, but my Husqavarna blower suggests that as part of the "prepare for storage" procedure.)
When I want to put away a 2 cycle for the season: I start it up and run it until it is warm so it will restart easily. Then I empty all the fuel out of the fuel tank through a funnel back to a small storage tank...pause long enough to push the primer bulb to pump (instead of fuel now) air through the works. Drain the fuel that returned during this pumping, and then put the cap on. Crank the engine, and let it run until it stops. This all serves to get as much fuel out as possible, and even protects the tiny pores in the fuel filter (in the tank) from getting clogged.
Looking at the Stabil site, their ethanol 411 links, it seems myths are growing about ethanol.
BoatUS Magazine: Three Ethanol Myths Clarified
Anyway, this was too long to read, but if you did so, accept my apology.:)
Bonus:
Coercivity - Wikipedia, the free encyclopedia
On the coercivity page, you get the see an example of magnetic hysteresis curves. Without magnetic hysteresis, the chart would look like a straight line with a certain slope. But, without magnetic hysteresis, a brushless alternator likely would never have been invented since it would have had to be flashed each time, or a battery would have to be installed.
Don't be mad...it was a bonus. Don't blame me for your hysteresis, you weren't even coerced! :D
   / Did I buy the wrong generator? #116
wow EE Bota, great info. Thanks
   / Did I buy the wrong generator? #118
So are you a drainer, let it run dry???
JB
   / Did I buy the wrong generator? #119
JB
Draining is better than running it dry. Either is better than nothing.
Fuel cutoffs should be used each time if present, and if practical to do, install them if absent.
If something will be used at least within the month, although I always turn off a fuel valve, I'd NOT drain, nor run it out in that case.
Longer term storage...tank 95 % full of stabilized fuel, the fuel valve turned off, and the carb hopefully drained, but if not possible, run out instead.
   / Did I buy the wrong generator? #120
If anyone is concerned about engine damage when killing the engine by cutting off the fuel, be aware that aircraft engines are shut off the same way.
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
