Did a little hay last week ...
   / Did a little hay last week ...
Hey they finally came and hayed my 9 ac weedy West field. It turned out 69 4x4 rolls...I guess the Urea helped a bit eh?
I guess it did ... thats a good crop of hay!!
They load half full of water and I believe 2gallons of antifreeze and man it makes it a whole different tractor,and drives alot smoother. I think if your totally over the rim it would make them alittle top heavy cause leaning on hill brings the fluid level on top of rim and more weight is on top of axle from both sides now leaning higher up(2cents). Ever thought about letting some out and trying it until it feels good?
Well I passed my test,not scared to admit only made an 86 but boy dont wonna take that class again,oh yeah 100 questions. Now gotta wait 8wks for liscence.
Talked to dealer may have tractor ready tomorrow and I will pick up,still need to get stuff out of my tool box.
Thanks for the birthday wishes and the congrats. New Orange:thumbsup: Now gotta load hay equipment up and get ready to bale in cple weeks. Thank you lord for the rain, all you have done for me, my family and my TBN friends/family.....
Congrats on passing the test .. I have my tires filled to the point when the valve stem is at 12 o'clock thats the fluid level ... I have pretty much flat ground and sure do appreciate the extra weight ... How did I make that decision? I had the tire shop fill them and thats where they put them. How much rain did your get? My gauge showed 2/10ths ... irrigation starts again tomorrow.
   / Did a little hay last week ... #413
Pacer, are you sure you have salt water in your tires? Man that has to be hard on the rims. There are several chemicals out there that won't rust the rims, so you might want to think about getting rid of that corrosive.
   / Did a little hay last week ... #414
3&1/2 inches in leona and 1/4inch at the house,it went all around us everytime.
   / Did a little hay last week ... #415
Salt solution is only in the my old Ford 3910, since new in 1989. Tires have tubes in them so no salt contact with the rims. I've had a couple honey locust tree thorn leeks over the years so there was probably some salt exposure when the tire guy drained them out to repair the tubes here at the farm. Lots of thorn leaks in the front tires but the old ford is 2WD and the front tires are not loaded, just tubed.
I had to replace one of the old original rear tires a couple years ago as the cords went bad in the center on an area about a foot in diameter.
They took the tractor wheel to the tire shop to replace the tire and tube so I went in to look at the rim inside while the tire was off.
It looked good but they cleaned and painted it with a rust inhibitor as part of the old process. The salt does cause rust, as I found next spring that the outside of the rim that had the tire changed had rusted at the rim nuts and where paint had been scratched or chipped on the rim. A little sanding, priming, and a spray can of Ford grey/white wheel paint and they look like new ( at least from a few feet away so the runs don't show):cool:
The modern method, up here where we do get below zero once in a while, and what they used on my CNH which is 4WD and has tubless ag radial tires, is to use a solution similar to ( probably the same as ) windshield washer fluid. It is not as heavy per gallon as salt water so they really make the tires full. Even had some come out with the valves at high noon position.
I have since found that you are really supposed to check the tire pressure of filled tires with the valve at 6 p.m. so I got a wet pressure gauge. They are the same price as a dry one and look the same but have a spring to return the stem to zero and push out any water.
I must admit to using the old "look and kick" method on the old Ford to check the tires but since the tire guy said the cord destruction in the old rear tire may have been partially caused by not enough pressure, especially since I leave a back hoe on it most of the time now, I'm trying to be a little more conscientious about checking tire pressures.
The big storm that took off a lot of our house roofing 2 weeks ago also sheared off many trees and limbs about 15-20 ft in the air so I have been using the old tractor to pull down the "widow makers" I can get a chain on and hauling off tons of limbs and partial trees. A number of them are honey locust with big black 2" thorns so I slide back the barn door every morning praying not to see any flat tires.
The old tractor is all heavy metal construction and still my favorite do anything, fuel efficient, tractor. Sort of like BlueRivers Montana tractor.
One of the things I really don't like about the newer tractors is all the use of plastic. The FEL on the CNH is nice looking with all the hydraulic lines mostly hidden, except for the obnoxious quick disconnect center bracket on the side that is just tempting some tree to tear it off. There are a lot of fancy plastic covers on the cross frame, snap on covers over the zerks, and other places where tree limbs/trunks would destroy them in one hit/push/haul. All the fancy headlights, even with the FEL guard would probably be broken in one session of messing with trees.
I'm afraid fancy new tractors are getting like fancy pick up trucks, "too purty to get dirty" :2cents:
Ron
   / Did a little hay last week ... #416
Well we had 4&1/2 in rain gauge poored out this morning then got another 3/10's this afternoon:thumbsup:
I got her home:D new 7040.JPGnew 7040#2.JPGnew 7040#3.JPG
   / Did a little hay last week ... #418
Yeah I was in Leona(in-laws,lease place),still only 1/4inch at house. I dropped of tractor and have to haul the rake and cutter next time down this way,the wifes cousins down the rode in leona going to be on there 4th cutting next week,man there meadows looks nice and only thing done was chicken litter on it last year and sprayed 2-4d/liquid 7 this year.
Im only going to get the one cutting in Leona but im glad to have it.
   / Did a little hay last week ... #419
Sold around 100 around bales this weekend. People traveling hundreds of miles for hay. What's going on with hay? We've had our share of rain this year unlike last year.
   / Did a little hay last week ... #420
If everyone is like us we havent made what we needed in cple years now so had to buy and still didnt get enough to have some extra to carry over at $100bale. I have two places 40 miles apart this week had 6in. at one and 1/4in.at other and pastures havent fully recovered yet from last year so if rain stops pastures not going to hold up much longer,so may have to start feeding Hay end of August. I guess knowbody wonts to get in a bind like last year.
Hey Todd I poured the 3/10's out then got another 1in. in gauge before I left leona,then they texted me was raining again an hr later,may need to run up to the JD dealer:D
2148 (A58376)
2148 (A58376)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
20ft Shipping Container (A57453)
20ft Shipping...
2012 Bobcat 90" Finish Mower (A57148)
2012 Bobcat 90"...
Swict 84" Bucket (A57149)
Swict 84" Bucket...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
