Diagram for correct placement of hydraulic hose
   / Diagram for correct placement of hydraulic hose #1
sjmedin
Kubota L4330
Does anyone have a diagram of correct placement on hoses on a Kubota L853 loader mounted on
a Kubota L4330 tractor with cab
   / Diagram for correct placement of hydraulic hose #2
Did you cross some lines on a valve or something? If so you can look at the valve pattern and connect it to the proper cylinder.
   / Diagram for correct placement of hydraulic hose #3
Which hoses? There are alot of them and they arent exactly labeled. You just have to trace them from one point to the next.
IF you could clarify what exactly you have going on, and which hoses specifically you are questioning, and possibly include some pictures, Im sure we could be a lot more help
I need to know which hoses are pressure and which are return. Removed hoses and can't get
loader to function properly after replacing them.
Yes, I don't know which is pressure and which is return on valve body. Tried to attach another hydraulic ram to it but
did not work and loader would only raise to a limited height, connected hoses back and loader functioned properly. doesn't
make any sense.
   / Diagram for correct placement of hydraulic hose #6
Sounds like they were full of air. Full cycle lift & curl several times.
   / Diagram for correct placement of hydraulic hose #7
What "other ram" did you try and attach?
Are you attempting to install a 3rd function?
How many hoses hook to the loader valve. 6' or 7
2014 Dodge Avenger Sedan (A50324)
2014 Dodge Avenger...
7022 (A50322)
7022 (A50322)
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
23222 (A50323)
23222 (A50323)
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
