Diagnostic Help
   / Diagnostic Help #1
Roger9107
Waldheim, La
'68 Ford 3000
I have a 68 Ford 3000 gas tractor. The three point lift operates well with one catch- no load. With a moderate load 600 lbs. it will not lift unless I step on the draft control lever. I'm relatively sure this is not how it is intended to work. New hydraulic fluid to recommended level. It works fine when I do this so I feel that I am getting sufficient pressure off the pump. I use the tractor daily so it is difficult to shut it down. Any ideas would be appreciated.
   / Diagnostic Help #2
Tractor Supply Company has a reasonably priced shop manual with step by step adjustment procedure and pictures. I recommend you have it handy while making adjustments.
   / Diagnostic Help
If have a shop manual. It tells me how to make adjustments but it doesn't tell me what to adjust for a particular problem. I've tried the flow control with no success.
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2020 JOHN DEERE 332G (A50854)
2020 JOHN DEERE...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
