Diagnosing Tractor Bad Sound
   / Diagnosing Tractor Bad Sound #1
mmranch
Crested Butte, CO
TYM T603
It's the middle of snow season and a number of days ago, I started detecting a bad bang sound while snow plowing. Bang may be the wrong word to describe the sound. It has been very hard to detect. What with tons of snow and chains on the vehicle the ride is already rough.
But as I'm plowing along with the engine roaring and rock-n-roll blasting in my headphones, I feel an intermittent bang which resonates through the tractor up into my body. More of a feel than a sound. I wonder if I really felt something bad or was it just the rough ride. I get out of the tractor and check the chains and find some links loose. I go back to the shop and tie them down again and keep plowing. The bang is intermittent and very hard to diagnose. I know it has nothing to do with the FEL or backhoe that is attached as it happens when the FEL is lifted while driving. Seems to make the bangs in 4WD and 2WD. This goes on for days.
Yesterday, I plowed the road and the banging seemed like it was getting slightly worse. The engine is running fine and this sound would seem to be coming from either the front axle or the transmission. I checked the front axle oil and found it to be VERY low. I filled it up and finished the driveway but the banging continued. Trans oil was fine.
Then I called the snow plowing contractor to take over the plowing and parked the tractor in the shop. I am currently in the middle of another MAJOR project so I may not be able to focus on the tractor problem for several months. I'm trying to pre-think how I diagnose this problem.
Ideally, I need to dismount the FEL and backhoe and remove the chains to be able to drive the tractor with as little other stuff involved as possible. Then I can more easily detect the bangs with a smoother ride, etc. Since the front axle was low on oil, I'm thinking (hoping) it would be that rather than the transmission. I was thinking I would jack up the tractor and spin the front wheels by hand to see if there is binding, etc. I will also drain the front axle oil to see if there is more metal in the oil than normal and there might be metal chunks if damage has been done.
Just wondering if others have ideas for diagnosing a problem like this?
(Just so you know, I'm on the top of a remote mountain and taking the tractor to a repair shop would not be possible for months and cost many $$$.)
Thanks for any ideas!
   / Diagnosing Tractor Bad Sound #2
Either the front or rear axles are locked together and snap out of sync when the difference in rolling distance is too much for the gears to hold. Eventually something will break.
If it does it in 2wd, then the diff lock is the problem. Try to release it.
   / Diagnosing Tractor Bad Sound #3
I'm guessing you are talking about the TYM t603? Just wondering how much fluid did you have to add to the front end? Was it always low or do you notice a leak somewhere?
   / Diagnosing Tractor Bad Sound #4
Are you sure it's not a link of the tire chains grabbing something like the fender?
   / Diagnosing Tractor Bad Sound #5
Could be your chains. My chains are VERY tight, but at higher speeds I hear (and feel) a loud bang. It happens more at higher speeds, the faster I go, the more it bangs and the louder it gets. The only problem I have is finding out what part of the chain is hitting, and hitting where? I've jacked it up and had my wife sitting in the seat, in road gear, while I attempted to watch it. Never hits when jacked up. No idea, but only happens at high speeds with chains. So, its the chains. Not a big deal.
Could be your problem.
If its not the chains hitting something, then likely your gears. Depending on how often it bangs. Is it constant? Have you tried taking it out of 4 wheel?
Is this tractor only for snow removal? Why wait months, seems like this should probably be a priority, at least to diagnose and attempt a repair. Even if that means ordering parts, get them coming. I'm not you, I don't know what other irons are in your fire, but it it was me, this would be diagnosed asap, parts ordered, and fixed immediately.
   / Diagnosing Tractor Bad Sound #6
Not totally true it could be the driveline to the front end. Most tractors disconnect the driveline at the trans so even though it's in 2wd the front driveshaft is still spinning.
How ever loud banging is never good and never good to "leave and see what happens".
Thanks to all for the ideas!
Yes, the tractor is the TYM T603. It is used for MANY things including snow plowing, road building, forestry log skidding, roof clearing, etc.
I'm familiar with the chains hitting and have dealt with it many times over the years (I hope it's the chains!)... but I don't think that's it. My chains are tight and there's nothing moving about them except the tiny leftover bits (such as a few extra links) which are tied down with doubled wire. When these sometimes come loose they can make a banging sound. But I've checked many times and there are no loose bits at the moment and plenty of clearance for them to spin without hitting.
My concern is more focused on the internals of the front axle as I had to put in about 2 gallons to bring it up to full (think it holds about 4 gallons). I have not found a leak and may have not filled it properly when I changed the fluids a couple of months ago (dementia may be starting).
The banging sound is not uniform... it is very random and doesn't happen constantly (yet). Most of the time, the tractor operates in Mid range gears and sometimes in Low range gears (hardly ever in High range gears). The banging sound seems to be detectable in the Mid range gears such as M2 or M3. Not sure if I've felt it in L1, L2, L3, L4. The banging has been felt in 2WD as well as 4WD. The engagement/disengagement of 4WD happens in the transmission. But when in 2WD, I think the front drive shaft and front axle internals still spin as the front wheels roll along. Therefore... if there is damage inside the front axle, broken parts could be catching as things spin as it rolls.
Or there could be a problem in the transmission itself. I don't use Diff Lock and will have to read the manual to understand what it does. The Diff Lock pedal is below the seat area and I try not to touch it.
I will have to do some more diagnoses to understand and isolate the sound and see if the front axle is damaged or what.
I need to raise the front wheels and spin them to see what's going on there. Also need to drain the front axle to see how much metal is in the oil. Need to remove the front driveshaft cover to see how the shaft is looking (I've replaced that before).
Problem is... there is 3-4 feet of snow everywhere (including on roofs), etc. The tractor won't make it 10ft without chains on it so I can't take them off yet (takes about 4-6 hours to put them on properly). The hydraulics work fine so I can still use the FEL with manbasket to clear roofs & backhoe to dig snow. Contractor is handling the road for now but there is much more snow management to be done. And I've got other major projects going on too. So it may take me a while to figure this out.
Thanks again.
   / Diagnosing Tractor Bad Sound #8
With this new Info I would let it sit and pull the drain plug on the front diff to get about a cup of oil to take a look at. If your fluid is shiny or has chunks on it you have found your issue and it sounds expensive.
   / Diagnosing Tractor Bad Sound #9
Never heard of any FWA unit except big ag tractors that hold that much gear oil. Something isn't kosher.
   / Diagnosing Tractor Bad Sound #10
Per Tractordata.com
Front axle:17.4 qts
16.5 L
71062 (A49346)
71062 (A49346)
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A50854)
2019 TRITON...
2014 Nissan Maxima (A50324)
2014 Nissan Maxima...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2013 Nissan Sentra Passenger Car, VIN # 3N1AB7AP8DL772101 (A50324)
2013 Nissan Sentra...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
