Diagnosing a Walbro SDC-37A?
   / Diagnosing a Walbro SDC-37A? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
So I got a hair growing, and pulled the Mac 10-10 automatic out from all the sawdust under the Oliver band saw.
It's likely sat there, or in the vacinity for over twenty years now. It was the first power saw I bought when I bought this place, and was soon replaced by a spanking new ProMac 10-10.
I gave it a look over, to make sure it had spark, that the fasteners on the carb and covers were snug, and that there was a good air filter in case it ran ;-)
Well, It did run! Started right up actually, after I swilled the junk out of the fuel tank and took the kink out of the fuel line.
The engine stalled when left to idle after maybe 15 seconds bouncing arond on the floor. High speed went from fat to lean in around 1/4 turn of the screw. I thought I was golden, so shut it down to fit a bar and fill the oil tank. As well as add a bit more fuel to the tank.
Well, after doing that, It would NOT start. It will hit a couple of times after a squirt of fuel down the carb throat. But popping only at dead idle with no added throttle. As soon as the trigger is pulled it dies, and it dies on it's own after just a few seconds after firing up. Seems like something changed and it's no longer getting fuel.
But it IS getting fuel! I've stripped the SDC-37A Walboro twice, looking for an "issue".
Sure the flex diaphrams are a bit saggy, but they are soft and pliable. I've seen worse running fine. The needle looks good, and the carb holds 15psi down to 9-10 psi over about 2 minutes. And each time I've opened up the carb it's full of fuel. I set the fuel screwa out 1 1/4 low and 1 turn High for starters. Maybe thats not right, but it was running on those settings +/-.
Compression is good, spark is bright, though the plug was wet when I pulled it before supper. Maybe it's flooded?
I'm thinking it may be the high speed check valve, but I don't know how to check that directly. I've pushed a fine wire through the needle screw hole, and squirted carb cleaner both ways into the space covered by the welch plug. No debris was noted that would go along with a clog or deteriorated check disc.
It ran well enough, then suddenly won't start.
The saw is on the bench, the carb installed again. I'm going around to a couple of shops tomorrow to see if I can get a carb kit.
Looking for ideas.
Boy is that saw LOUD!, and you should have seen the plug of dried bar oil I pulled from the oiler port! ;-)
   / Diagnosing a Walbro SDC-37A? #2
Yeah, those things are sure loud for the work they do :)
I've had that happen before, usually it's from a bad metering diaphragm but I've been stumped before, like the slightly newer similar size Homelite 330 that's doing similar torn apart in my shop...
   / Diagnosing a Walbro SDC-37A? #3
Do the carb kit and go from there.
If you get it to stay running, spray some brake cleaner on the outside of the saw by the PTO side crank seal and the flywheel side crank seal. If the saw dies, you also have an air leak. If no air leak, run that sucker.
So I went into town to see about picking up a carb kit.
"NLA, try the internet" was all the parts guy could tell me.
But when I returned home, I started looking around the shop for the bucking dogs "I know I have somewhere", Of course that leads to all sorts of distractions. The afternoon went by quickly as I puttered.
Just about the time I was going to break off for supper, I came across a small box in a high shelf labled "10-10 stuff". Sure enough, there was a carb kit in there! bought in '09, from the same place I tried today. It doesn't take long to put those bits into a carb.
But I had drained out the fuel, and the time slipped by, so I didn't get to try to run it with the new parts this evening.
Tomorrow....;-)
Well, Well,
I was going nowhere fast on this saw, and then it started to drag on the starter. Wore me out a couple of times. I put a socket wrench on the drive and could just manage to turn the engine over.
Decision time! Toss the saw, or look into it to try to learn something.
I'm dumb, so I choose the latter. ;-)
Turns out, the crank shaft had shifted on the roller bearing and the crank lobes were rubbing on the inside case. Might be due to hamfisted efforts to get the flywheel off, but "someone" had made up two thin teflon sheet washers that fit between the points case and the underside of the flywheel. I wonder what that was about?
Anyway, the bearing is pressed home, it all spins, but it's still apart on the bench.
Crank seals and some paint! Then another try.
Well, well, Further goes the saga.
I stripped down this Mac 10-10 Automatic to bare cases last week. Yesterday, I Put it all back together. using a length of 1/8th" o.d. fuel for the fuel tank seal. (A different solution)
A squirt of fuel in the carb bore and it popped on the second pull. With a bit of coaxing, I got it to run ...sort of...
The engine doesn't really respond to the fuel screws. And there was fuel spraying all over from the carb throat while it did run.
Too much fuel!
So off came the carb for it's umpteenth strip down and look see.
Well what do you suppose? The high speed welch plug was laying on top of the fuel needle retaining screw and there I was, looking straight down at the High speed screw. OH! That would let a bit of extra fuel by! ;-)
The screen underneath looked good, Spritzed a bit of cleaner through all the passeges.
Put some sealer on the rim of the welch plug and flattened it home.
I'll wait for tomorrow to let the sealer set/ (Permatex aviation form a gasket)
Then give it another go!
Sure hope all is well with the check valve under that screen ;-)
These old saws are simple, but they sure have a lot of parts!
CAT 930M (A58214)
CAT 930M (A58214)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
