diagnose help
/ diagnose help #1
BiXLL
I have a LT 1042 with a 19 horse Kohler. has 190 hours on it. Today while cutting it started sputtering and sounding funny then shut down. Cranks over great but sounds like a popping sound from exhaust. I have over 100 lbs compresion, getting great spark, and gewtting fuel. Does not even try to start, just turns over. Any ideas?
/ diagnose help #2
If you have the Courage engine they are known for shearing the flywheel key which would throw the timing off. It's not always obvious by just looking at the flywheel and may require pulling it. They use a soft key to prevent damage and some engines didn't have the flywheel torqued correctly.
Bob B.
/ diagnose help
That is what I am thinking the problem is after doing some more research. I am going to check into it today. Where in the world would I buy a flywheel key?
/ diagnose help #4
Sheared flywheel keys on riders are rare, and unless you have had the flywheel off recently I doubt that is what it is. I would start looking more into valve issues, start by pulling the valve cover and removing the spark plug and turn the engine over by hand and watch the valves. Push rod issues and camshaft issue are more common than flywheel keys. Hitting hard objects and killing the engine normally won't shear the key on a rider engine. Too many things to absorb the impact. between the deck/drive and the engine.
/ diagnose help
It was not the key. Still it says timing issue to me? It turns over slowly, like a low battery and its backfiring through the carb. I guess I'll pull the valve cover, but I do not know what I am looking at. I have never worked on a small engine like this.
/ diagnose help
Randy, you hit it! I pulled the valve cover off and found a rocker arm not connected to a push rod. Now I just gotta a search valve adjustment on this motor and I think I will be golden!
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
WEILER P265 ASPHALT PAVER (A65053)
WEILER P265...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
