Diabetes
/ Diabetes #831
For the last 4 or so, all my dexcom 7 sensors have failed a few days early, so I'd guess they switched the formula or manufacture. Anyone else seeing that?
Did you reach out to DexCom to let him know and get their response? At the very least, they should have an explanation, otherwise, that's a reportable item.
All the best, Peter
/ Diabetes #834
If anyone here uses Dexocm 7's, do tell us how they are doing. All mine have flailed prematurely and before 10 days time, in the past three months.
/ Diabetes
worrisome to get repeated failures
hard to believe stringent QC on medical devices failed and they let a bunch of bad units out
what is failing; do they know? Is it the patch or the receiver? sounds like short battery life
/ Diabetes #836
Its the senor's that fail before there stated 10 day length. Seems they should be called 9 day sensor or maybe a 8. Dexom changed the formula for the string or its manufacturer did. Historically life expectancy seems good for a year or two, then something gets changed and they start to fail prematurely. My last 4 or 5 have done that. On didn't work at all after installation.
/ Diabetes
Arly, clearly you are just too sweet for these units... ;)
may I assume there is a tiny lithium battery in there powering the transmitter?
too bad they don't make rechargeable ones, or do they?
/ Diabetes #838
Dexom changed the formula for the sensing string or its manufacturer did. That's the part that does the actual BG sensing.
/ Diabetes
/ Diabetes #840
I had my last one make it to the end of its cycle, which is first to do that in months. I didn't keep track if it was one from the drug store, or a replacement model. :unsure:
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
2018 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A59230)
2018 Peterbilt 320...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2020 VOLVO VNL760 TANDEM AXLE SLEEPER (A59906)
2020 VOLVO VNL760...
General Purpose Loader Bucket (A59228)
General Purpose...
