Diabetes
/ Diabetes #731
I'd guess you are using a CGM?
thats the only way to go with this stuff. There is so many ups and down you will miss by doing finger sticks alone. The app records your daily averages, and time in range etc.
Without a CGM I would never know that sometimes I will dip down to 50 at night. id never be up at 2 am pricking my finger to ck.
/ Diabetes #732
Man-o-man you got that right!
/ Diabetes #733
has anyone had any experience with this AIC home health test kit?
you get two in the box
As a medical device, these have to meet the standard for the type of device. In this case, here are the specifications from the equivalent Bayer unit;
The focus here is for A1C values between 6-8.
Here the focus is that the values are within 0.1% of the standard reference method for A1C testing.
FWIW: This particular device (CVS Health At Home A1C Test Kit)
has a recall on it due to a software bug that doesn't display correctly for values under 4% or over 13%;
All the best,
Peter
/ Diabetes #734
And of course with new technology and new data, it opens up new questions. Is BG going down to 50 while we sleep an issue at all? With the Dawn Effect, I found that my BG was lowest around 4am and without eating anything it will gradually go up till 10-11am. So if you're testing you BG with strips, it's highly recommended that you do it at the same time every day when you get up and before you eat anything. That way it's taking out the dawn effect variation.
/ Diabetes #735
50 is low, to low.
/ Diabetes #736
50 is low, to low.
Mine will dip to 50 at night once or twice a month but comes right back up. Have not found it to coincide with anything. ie: eating late, or eating a carb etc.
I feel no different when its at 50, than I did when mine was over 600, or when its at 120.
According to the CGM Im averaging 88% of the time below 125. Highest spike ive seen was 201 and that came from a pork chop and gravy biscuit. My spikes go up and come down fairly quickly. I was told when they spike and plateau remaining high for a while before coming down is bad.
Im not taking any insulin. Just diet alone.
/ Diabetes #737
That's pretty low. Your CGM was be screaming at you at this point. My head is usually spinning at 50. (more than normal anyway) :ROFLMAO:
/ Diabetes
lot of metrics here to follow, not only levels but rate of rise and rate of fall
at some point there must be guidelines as to what is
severe and what are normal ups and downs.
seems there are ranges and as long as we don't exceed ranges, then
maybe we are doing ok.
but without a CGM, don't know how you could be informed well enough
is it possible to have dangerous blood sugar spiking and not have an issue with
AIC?
how many things should light up the check engine light?...
/ Diabetes #739
yes, it sounds off below 60 or above 150. if it wasnt for the CGM id never know when I was low or high. When I was over 600 in hospital they asked me 100 times how i felt. It felt just like any other day to me. No headaches, vision problems, lightheaded etc.
/ Diabetes #740
AIC?
Id like to see a "normal persons" daily charting with a CGM. One of the docs told me spiking is normal, but couldnt tell me spiking to what # is acceptable?
what do normal peoples spike too? 150? 175? 200? or is theirs more of a flat stable line across. I can hit a 175 spike from say 85, and withen 2 hours its back down to 100.
Now, if i eat breads or sweets.it may take 3 hours to come back down to 110.
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
Volvo EC220EL (A60462)
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2007 Sterling 360 COE 40/45 Box Truck (A59230)
2007 Sterling 360...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A59230)
2012 Mack CXU613...
