Fuddyduddy1952
Super Member
- Joined
- Aug 10, 2022
- Messages
- 9,884
- Tractor
- john deere
I meant 50 UNITS not cc.
Her A1C I just asked is in the 6's.
Ya, kinda figured that. Her a1c is kinda high. Has anyone spoke with her about getting a pump? She is seeing awful high glycogen swings.I meant 50 UNITS not cc.
Size matters!I meant 50 UNITS not cc.
Carrying that extra weight requires more insulin to keep ones BG down and the more you need to take, the less sensitive you become to insulin and other negative factors.A big risk factor for type 2 diabetes is obesity. I have no idea why. Losing 90 lbs. made a big difference.
Did you reach out to DexCom to let him know and get their response? At the very least, they should have an explanation, otherwise, that's a reportable item.For the last 4 or so, all my dexcom 7 sensors have failed a few days early, so I'd guess they switched the formula or manufacture. Anyone else seeing that?
Yes, we always do, Are you a dexcom user as well?Did you reach out to DexCom to let him know and get their response? At the very least, they should have an explanation, otherwise, that's a reportable item.
All the best, Peter
Dexom changed the formula for the sensing string or its manufacturer did. That's the part that does the actual BG sensing.Arly, clearly you are just too sweet for these units...
may I assume there is a tiny lithium battery in there powering the transmitter?
too bad they don't make rechargeable ones, or do they?
